| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
So, I'm making a small radio-reciever that will eventually connect to a loudspeaker.
I'm using 2 741 op-amps, one of which has a variable resistor on the negative feedback loop acting as a volume control. I then have output (pin 6) of the second 741 connected thohg a capacitor to a push-pull circuit using one P and one N channel MOSFET. I've looked around on the internet, but can't find any circuit diagrams as to where to connect the negative feedback to, I've been told that it connects to somewhere around the MOSFET's, but that's all the info. i've been given. |
#2
The 741 opamp is really not a great choice. You'd be far better off using a TL071 or TL072 (single and dual opamps, respectively).
The TL071/72 has far greater bandwidth and far lower noise. Usually, the opamps are configured for a set amount of gain, and a pot (10k audio taper) is used to attenuate the input signal. One end of the pot is connected to ground, the other end to the input signal, and the wiper is attached to the input of the amplifier. If you're using a single-ended supply, you will need to use a cap between the wiper of the pot and the input of the opamp.
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. |
| Bookmarks |
| Tags |
| amp, circuit, feedback, loop, mosfet, negative, power, push-pull |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cold Plasma Circuit | ablaty | The Projects Forum | 7 | 11-08-2009 05:31 PM |
| Math Help with a Simple LED circuit | fish4fun | The Projects Forum | 3 | 03-03-2009 04:04 AM |
| Weird op amp problem... LM324, feedback loop... | ARMDeveloper | General Electronics Chat | 4 | 09-28-2007 02:26 PM |
| Help me calculate the power developed by this simple circuit. | NichA | Homework Help | 4 | 06-17-2007 05:25 AM |
| How does the negative feedback of an op-amp control the output? | NichA | General Electronics Chat | 15 | 06-13-2007 05:51 AM |
