All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-03-2010, 06:24 AM
kachung30 kachung30 is offline
Default HOW TO design antilog/log circuit?
l need to do multiplier by OP-AMP. But l don't know suitable ic value . ie transistor, resisitor ,etc
thank you
  #2
Old 02-03-2010, 10:03 AM
t06afre's Avatar
t06afre t06afre is offline
Default
I have an old book from Burr Brown at home. I shall see if I can find it. But you should be aware of that is many problems with such circuits. As an example they do not work very well at low inputs level. What are your trying to make. It could that is better solution to your problem.
  #3
Old 02-03-2010, 01:44 PM
Default
I am trying to design an voltage multipliers to calculate output voltage. output is a^b
  #4
Old 02-03-2010, 01:55 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
As you are no doubt aware, multiplication is a non-linear operation. The construction and use of non-linear circuits have numerous problems including the need to scale the output to prevent saturation.
The use of a logarithmic amplifier is straight forward, but the inverse operation of raising to a power has the problems of saturation and output scaling.
Check application notes from National Semiconductor for ideas on these beasties.
__________________
We never have time to do it right,
But we always have time to do it over.
  #5
Old 02-03-2010, 05:10 PM
MikeML's Avatar
MikeML MikeML is offline
Default
some light reading. Analog Devices makes log, anti-log, multiplier, and divider ICs.
__________________
Mike ML.
I am an engineer and academic. When I talk about current it flows from positive to negative.
  #6
Old 02-03-2010, 05:17 PM
jans123's Avatar
jans123 jans123 is offline
Junior Member
Default
Right, National was my "tutor" many years ago, long before the application note http://www.national.com/an/AN/AN-311.pdf was published. Look at it, it might give some hints.
  #7
Old 02-03-2010, 05:39 PM
steveb steveb is offline
Default
Quote:
What frequency bandwidth, (or response time) do you need? If you need high speed (MHz for example) you will likely need an analog approach as discussed above. To avoid the difficult design work, you can buy an existing chip, but they are expensive.
However, if you don't need high bandwidth, you can use a cheap microprocessor with built in A/D and D/A converters. All types of nonlinear operations (including multiplication) can be easily handled in programming.
  #8
Old 02-03-2010, 06:05 PM
KL7AJ KL7AJ is offline
E-book Developer
Default
Might also look at a Gilbert cell. These are true multipliers, but they have limited dynamic range, so need careful signal conditioning beforehand.
Gilbert cells can be made with six transistors.
eric
__________________
REAL men don't need voltmeters.
  #9
Old 02-04-2010, 05:08 AM
Default
The op-amp must be used uA741.and l want to know the model of diode and value of resistor.
  #10
Old 02-04-2010, 12:33 PM
beenthere's Avatar
beenthere beenthere is offline
Default
As long as you are using obsolete op amps, you can use the great old National Semiconductor op amp circuits collection - www.national.com/analog/amplifiers/application_notes- select AN-31
Just about any old diode will work. Try a 1N914. The resistance value has to do with the end point of the input voltage. As the current through the resistor has to be matched by current through the diode, a reasonable resistance will keep the current below the output current limit of the op amp at the upper range of the input voltage.
Be aware that the log response of your circuit is temperature dependent. For analog computation to have any repeatability, you will need to use something like the op amp collection circuit with temperature compensation. Notice there is an analog multiplier circuit in there, too.
__________________
First comes the hardware, then the software.
Tags
Related Site Pages
Section Title
Worksheet Calculus for electric circuits
Worksheet Nonlinear opamp circuits
Worksheet Logarithms for analog circuits
Worksheet Signal modulation
Textbook Computational circuits : Practical Analog Semiconductor Circuits
Textbook Logarithms : Algebra Reference
Textbook Precision voltage follower : Analog Integrated Circuits
Textbook Introduction : Analog Integrated Circuits
Textbook Decibels : Amplifiers And Active Devices
Textbook pH measurement : Electrical Instrumentation Signals
Similar Threads
Thread Thread Starter Forum Replies Last Post
5V - 12V circuit design mblair86 The Projects Forum 5 10-31-2009 05:18 AM
low power consumption audio circuit design tips rick5 General Electronics Chat 1 05-15-2009 11:18 PM
Diode circuit design problem Alice Homework Help 2 03-23-2009 11:44 PM
Need advice on circuit design? electronice123 General Electronics Chat 11 02-07-2009 03:19 AM
PCB Circuit Design - First time deefactorial General Electronics Chat 11 07-21-2008 09:59 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
