All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-01-2010, 01:29 AM
jayanthyk192's Avatar
jayanthyk192 jayanthyk192 is offline
Member
Default run the spindle motor
hey....i am in need of a circuit(external) to run the spindle motor of an old hard drive using a battery.please suggest me a circuit
  #2
Old 02-01-2010, 01:32 AM
BMorse's Avatar
BMorse BMorse is offline
Default
Quote:
In order for it to spin, you will need to provide the drive with +5 and +12 volts DC... given the hard drive still works....
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #3
Old 02-01-2010, 07:09 AM
Member
Default
i actually want the motor for one of my projects & it is necessery that i run with a battery using a controller circuit.so plese suggest a circuit.
  #4
Old 02-01-2010, 01:29 PM
BMorse's Avatar
Default
So you want to run a 12 volt motor off of batteries?? What type of batteries are you going to be using? Even with some D cell batteries, they would not last long running a 12 volt motor. And most of those motors are a 3 wire stepper type motor.... good luck controlling that with batteries..... I hope you have a backpack to carry all those batteries to run that small motor....
__________________
  #5
Old 02-02-2010, 03:54 AM
Member
Default
okay,if it requires 12V then i could power it with with an ac adapter I already have.but giving 5V as well as 12V at a time is pretty difficult as i dont have an SMPS,and moreover i dont get to control the speed of motor using the circuit board of the hard disk.so,i'm searching a circuit.
  #6
Old 02-02-2010, 04:44 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
I think hard drive motors are BLDC's nowadays (Brushless DC motors) - they're actually run by 3-phase power.
See if you can read the part numbers from IC's near the motor connector. The motor connection harness will probably look like a ribbon with 4 wires/traces in it.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #7
Old 02-02-2010, 06:53 AM
3ldon 3ldon is offline
Member
Default
If you can manage taking the motor driver off the board, and you know it works, its easy.
none of them require more than a few pull up resistors, and bootstrap capacitor(s).
Most are only good to 3 watts.
I have found most to be controlled via a custom digital link, and the datasheets to be quite informative.
  #8
Old 02-02-2010, 02:13 PM
BMorse's Avatar
Default
I don't know what kind of hard drives everybody uses, but most of them nowadays are 3 wire, and they can not just be connected to power, the control IC is a 100 Pin QFP....
__________________
  #9
Old 02-03-2010, 11:28 AM
Member
Default
i tried tracing the leads of the motor,but the circuit is multilayered and i could'nt trace the leads to the control IC as the leads are inbetween the two outer layers and not visible clearly.
  #10
Old 02-03-2010, 11:53 AM
Member
Default
Quote:
Attachment 15874
Attachment 15875
Attachment 15876
Attachment 15877
the HDD i have has a four lead stepper.I also found it is a star connection.
Tags
Related Site Pages
Section Title
Worksheet Protective relay circuits
Worksheet Latch circuits
Worksheet Servo motor systems
Worksheet Bipolar junction transistors as switches
Textbook Credits : Contributor List
Worksheet AC motor control circuits
Worksheet AC motor theory
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Synchronous Motors : Ac Motors
Worksheet DC motor theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC motor run capacitor walley10291 General Electronics Chat 14 06-26-2012 02:20 PM
Belt grinder: motor choice and speed control someonesdad The Projects Forum 13 11-29-2009 08:52 PM
how can i run a 2v motor with an op amp? rashedul hasan Homework Help 13 11-27-2008 08:26 PM
Project: Torque converter for slow speed motor hobbyist The Completed Projects Collection 2 10-30-2008 06:56 PM
PSC motor capacitor trouble ericaustin The Projects Forum 3 07-28-2008 05:12 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
