All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-23-2006, 09:40 AM
Neil Charlton Neil Charlton is offline
Default Measuring 4-20ma and 0-10v
When using 4-20 ma and 0-10v variable signals do the supplies for the variable signals need to originate from the measuring device?
I was hoping to find out if it's possible to continue to utilize a 4-20 ma output (from a pressure transducer - picked up by a proprietary industrial controller) and then also feed the same variable output (in parallel) from this transducer into another different industrial controller (motor vsd) as a 0-10v input, (provided the output voltage does vary from approximately 0-10v).
Any advice would be greatly appreciated.
  #2
Old 09-23-2006, 10:42 AM
multi multi is offline
Default
Hai Neil
U r doing the right way of interfacing the pressure sensor with transducer which will generatre proportion output signal inthe form of voltage or current which will be feeded to your industrial controller to control the the final parameter.
It is advisable to use isolated analog output in the form of voltage/current before feeding it to the industrial controller.
  #3
Old 09-23-2006, 05:41 PM
Syed Syed is offline
Default
Hello, Neil Charlton
It is not a must to use the power from the indicator / controller, external power supplies can be used. You can convert 4-20 mA into 2-10 V by a shunt resistance (500 ohms) but a special converter is required to convert 4-20 mA to 0 – 10 V. It is possible to connect a number of devices with one transmitter. The total resistance of these devices should be within the specified maximum value for the particular transmitter and these devices must have isolated inputs.
  #4
Old 09-25-2006, 02:51 AM
oldbird oldbird is offline
Default
Hi
You can use Avago's linear opticoupler such as HCNR201 to do that.There are some ANs to tell you how.
Tags
Related Site Pages
Section Title
Worksheet Linear computational circuitry
Worksheet Regulated power sources
Worksheet Superposition theorem
Textbook AC instrumentation transducers : Ac Metering Circuits
Worksheet DC transducers
Textbook Computational circuits : Practical Analog Semiconductor Circuits
Textbook Voltage-to-current signal conversion : Operational Amplifiers
Textbook Introduction : Digital Communication
Textbook Current signal systems : Electrical Instrumentation Signals
Textbook Analog and digital signals : Electrical Instrumentation Signals
Similar Threads
Thread Thread Starter Forum Replies Last Post
blower controle help! 4 20ma 0- 10vdc. Guss Bort General Electronics Chat 7 06-29-2013 09:17 PM
LVCMOS -> Darlington Array -> 8 20mA LEDs (parallel) mbird General Electronics Chat 0 03-12-2012 08:22 PM
Need to make 4 - 20mA loop isolators bowlingo The Projects Forum 10 02-19-2012 05:44 PM
Convert O to 10V into 4 to 20mA circuit diagram required jcp General Electronics Chat 1 04-12-2011 11:49 AM
5vdc reed relay - 2.6A power supply need to step it down to 20mA jmeredith The Projects Forum 15 11-22-2009 10:08 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
