I want to build a CMOS inverter circuit (1 pmos on top, 1 nmos on bottom) on a breadboard. Is this possible to do with an nmos and a pmos you would buy from mouser or digikey? Or do you have to buy a special IC to use it? Can you find an NMOS and a PMOS that have the same parameters that would allow it to work? Further, I want a decent amount of current to flow through these, so could I make this inverter from typical power mosfets ?
