| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
sorry if this question is too basic but I am stumped by it! I'm making a circuit on stripboard and want to use terminal blocks to attach wires rather than soldering them to the board. After much searching I still can't find blocks which fit my stripboard - are they a PCB only thing or have I not looked hard enough them? Would you bend the pins of terminals made for PCBs and force them to fit into stripboard? This is the stripboard I am using, http://www.rapidonline.com/Tools-Fas...ripboard/29453 I bought the 3 way terminal blocks on this page but the pins are too far apart for the board: http://www.rapidonline.com/Cables-Co...l-blocks/82656 I've looked all around the terminal blocks section, and on maplin, but they all seem to be made for PCBs. Thanks, Oggz |
#2
This type: http://www.rapidonline.com/Cables-Co...terminal+block
will probably work OK for you. The 5mm spacing is actually 5.08mm, which is 0.2" - or every other strip in your stripboard. If you want terminals on EVERY strip, then you'll need to stagger a couple of rows of terminal blocks. If space is tight, you could stagger two-tier type; like these: http://www.rapidonline.com/Cables-Co...terminal+block
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. |
#4
Brilliant, thank you both. I didn't know that 'pitch' was the measurement to check.
#5
I didn't even think about that; "pitch" does seem a silly name for the pin spacing. I guess that is a UK thing; in the States they usually simply call it "spacing". We sometimes use "pitch" when referring to threads on screws.
__________________
#6
Quote:
![]() ![]() Eric
__________________
REAL men don't need voltmeters. |
#7
Nope, it's still "pitch" on this side of the Atlantic. Check page 200 of the current Digi-Key catalog (January - December 2010).
__________________
First comes the hardware, then the software. |
| Bookmarks |
| Tags |
| beginner, blocks, fit, stripboard, terminal, terminal blocks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| First fit and best fit | muni | Computing and Networks | 2 | 08-14-2009 09:58 PM |
| General design question for PIC based hand held terminal | dk-info | Programmer's Corner | 2 | 03-25-2009 03:00 PM |
| Screw Terminal Connector | dude521 | General Electronics Chat | 4 | 02-05-2009 12:23 PM |
| digital building blocks | relicmarks | General Electronics Chat | 5 | 11-18-2008 12:40 AM |
| Why is there no GND on my DC Powersupply? | cds333 | General Electronics Chat | 25 | 11-10-2007 06:05 AM |
