All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-21-2010, 05:47 PM
luckyveloso luckyveloso is offline
Default need help in 12 hour format digital clock
badly need help in analyzing or implementing the circuit diagram of the hour part in 12 hour format clock using 74ls192 or 74ls90...tnx
  #2
Old 01-21-2010, 06:08 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
Take a look at the block diagram in this thread:
http://forum.allaboutcircuits.com/sh...ad.php?t=16859
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 01-21-2010, 06:57 PM
beenthere's Avatar
beenthere beenthere is offline
Default
How are you counting the seconds and minutes?
__________________
First comes the hardware, then the software.
  #4
Old 01-22-2010, 01:56 AM
Default
the seconds and minute part goes well, it counts from 0 - 59...the only problem is the hour, coz it dont start at 01...instead it start from 00 then ended at 12, then back to 00...
  #5
Old 01-22-2010, 02:02 AM
beenthere's Avatar
Default
Use the parallel load function on the '192.
__________________
  #6
Old 01-22-2010, 02:18 AM
Default
can you explain the concept of the parallel load??? i gladly appreciate it...
  #7
Old 01-22-2010, 12:08 PM
beenthere's Avatar
Default
It's all on the data sheet. Every logic IC has one. It explains all the dunctions and how to make use of them. Google using "74ls192" as the search term.
__________________
  #8
Old 01-22-2010, 12:09 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Basically you can force the chip to start at the number of your choice.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #9
Old 01-22-2010, 12:55 PM
sgardner025's Avatar
sgardner025 sgardner025 is offline
Member
Default
With the 192 you could tie P0 high and P1-P3 low on the 1's place hour counter and tie P0-P4 low on the 10's place hour counter. Then you could use some decoding to take the PL inputs low during the next low to high clock transition on the 1's place hour counter.
  #10
Old 01-24-2010, 07:16 AM
Default
Quote:
can you you show me the diagram or how you decode the PL inputs? i've been working this one for already a one week now and still i couldn't figure it out...pleaseee...thanks...
Tags
Related Site Pages
Section Title
Worksheet Counters
Textbook Ring counters : Shift Registers
Textbook Asynchronous counters : Sequential Circuits Counters
Similar Threads
Thread Thread Starter Forum Replies Last Post
need a circuit diagram of 24 hour digital clock lenn24 The Projects Forum 1 01-23-2009 02:40 PM
LCD and real clock timer apiz88 Programmer's Corner 3 10-03-2008 05:39 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
