All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Electronics Resources
Notices
Electronics Resources Get help with all types of electronics resources, including books, websites, datasheets, technical literature, and software.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-20-2010, 09:56 PM
loosewire loosewire is offline
Default Miniature Hydraulic
WE seem to have some members that are knowledgeable
on hydraulics take police robots,tell us how the small valves work
doing muliple task just talk about hydraulics not there
police duty, like other things like hands and knees.
  #2
Old 01-23-2010, 09:51 PM
rjenkins rjenkins is offline
Default
I've seen lots of miniature pneumatic gear used in industry & handling equipment etc., but never any truly miniature hydraulics.
Due to the typical pressures involved, hydraulics needs thicker wall pipes and larger couplings. Pneumatic cylinders operate at around 80 - 100 PSI, hydraulics often work in the 1000 - 2000 PSI range. Miniaturising is difficult.
I suspect anything really small and running from batteries will be using electric motor driven actuators of some sort.
I'm not saying such things don't exist, just that it's likely to be a last resort if no other type of actuator can be used.
You can get some info on the type of small tracked robot used for bomb disposal etc. here:
http://www.irobot.com/filelibrary/pd...Bot510_EOD.pdf
__________________
Robert Jenkins.
  #3
Old 01-23-2010, 10:45 PM
Default
What do they use for movable fingers.
  #4
Old 01-24-2010, 12:51 AM
retched's Avatar
retched retched is offline
Default
The robot hand I've worked with used pneumatic actuators in the wrist with a tendon(wire and pulley) system the the finger joints.
__________________
-rm-
  #5
Old 01-24-2010, 11:48 PM
VoodooMojo's Avatar
VoodooMojo VoodooMojo is offline
Default
Quote:
http://www.shadowrobot.com/hand/overview.shtml
pneumatics is a very efficient way.
A hydraulid circuit would involve actuators, pumps, valves (also relief valves as oil is not compressable). A hydraulic hand without relief valves would be a scarey thing!
Every component that oil has to run through costs energy.
The efficiency is lost with turning voltage and current into psi and gpm.
An electric motor turning a hydraulic pump to produce flow going through electric valves to a hydraulic actuator is costly.
Electric actuators are costly also.
Pneumatic hands sometimes just use the flexing of hoses to accomplish movement, pulleys and strings to accomplish grip..
It takes comparably less energy to pump air than to do it another way.
__________________
"Someone painted "April Fool" in big black letters on a Dead End sign."
  #6
Old 01-25-2010, 11:59 AM
Default
You could use model servos in the arm and 'snake' cables to the finger joints.
Snake cables are like push-pull bowden cables, one form of link between servos & rudder / elevator in a model aircraft.
Example:
http://www.mugi.co.uk/shop_product.php?id=74
There is a load of other servo linkage stuff on he left of that page.
__________________
Robert Jenkins.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
miniature elevator.. need help. voltz32 The Projects Forum 6 09-25-2009 03:22 AM
Voltage divider for hydraulic valve chrisaus2009 The Projects Forum 5 03-31-2009 12:44 PM
circuit design on 220v miniature elevator.. SenShuSaiki The Projects Forum 1 11-16-2008 04:42 AM
Hydraulic analogy, pressure and voltage. studiot Physics 7 05-21-2008 11:38 PM
elevator miniature sky Homework Help 0 10-13-2004 09:57 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
