All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Embedded Systems and Microcontrollers
Notices
Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-20-2010, 12:29 PM
milind213 milind213 is offline
Default cc2500 in uart mode
I am using cc2500 with atmega32.
I want to use cc2500 in uart mode because i think in spi mode it is too big to handle.
for that purpose i did following things:
1. i reset cc2500 using sres command strobe.(0x30)
2. then i configured the data rate to 9600 by writing appropriate values of DRATE_E and DRATE_M in respective registers.
3. then i configured gdo2 (=RX by writing 0x0D )and gdo0(=TX by writing 0x2D)
i configured all this using spi interface.
As i could successfully read back all written values everything is fine but this serial wireless link is not working.
Am i losing out on any step to make cc2500 work in uart mode?
please explain if so else what is the problem?
one more thing if you can explain how to work with cc2500 in spi mode (accessing tx rx FIFOs) it will be very useful. I have gone through datasheet and many of design notes but i am not understanding it clearly. I am using smartrf studio for my calculations
thnx ...
  #2
Old 05-06-2010, 01:34 PM
Eduard Eduard is offline
Default Cc2500
I have experience eith cc2500 chip.
Mainly I have used it in SPI mode but not in UART mode.
In SPI mode to access fifos you should simply read or write on burst bases.
What you mean <<< but this serial wireless link is not working.
did you have 2 blocks transmitter and receiver ?
  #3
Old 05-27-2010, 12:39 PM
k_general k_general is offline
Default
hey
I am also trying to interface cc2500 mounted in module QFM-TRX1-24G with 8 pin output with atmega16 but I didn't understand even how to send or receive data form the transceiver or how to configure the module
any advice or simple document about how to deal with it or at least understand it
Best Regards
Tags
Related Site Pages
Section Title
Worksheet Digital communication
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cc2500 milind213 Embedded Systems and Microcontrollers 1 01-16-2010 07:20 PM
Traffic Light Help PLEASE!!!!!!! sexycircuit Homework Help 12 11-30-2009 11:03 PM
Linear Mode-Saturation Mode-Avalanche Mode vibsie General Electronics Chat 1 10-04-2008 05:21 PM
LCD and real clock timer apiz88 Programmer's Corner 3 10-03-2008 05:39 AM
oscilloscope invert mode and ADD mode relicmarks General Electronics Chat 10 04-11-2008 03:16 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
