Help Newbie How Delay power on relay
cfoek
Joined Jan 16, 2010
8
helo .. I need help make delay timer schematic. When i push the button then delay for 2 seconds and turn the relay on and off. i have googling but can't find what i need so can anyone help me?
thanks guys
Wendy
Joined Mar 24, 2008
23,429
The key to this problem is two monostables, one feeding another. You need to break the problem down. You're going to find it is better to have an understanding how things work, you can build on them to create something new and original.
You start with the basic 555 monostable (which is straight out of the data sheet).
Then you add a transistor to drive the relay.
And you merge them. You did not state how long you wanted the relay on for, so I assumed 1 second.
Have you read this?
555 Monostable
Bill's Index
You could use one 556 (a dual 555) instead of two 555 chips. This datasheet I drew up a while back will help with the converstions.
BRB, drawing schematic....
cfoek
Joined Jan 16, 2010
8
thanks for your replay Bill Marsden
yes 1 second will be enough i will connect the relay to other monostable (already build and work)
so basically i need 2 monostable from fig 1 and the cap will connect from R1 to Rt then to pin2 555?
where i put the ground from R1 or Rt ?
where i put the push button?
can you guide me because i'm still new to design a circuit hehehehe.....
i have read some explanation of 555 but still confused hehehehe ....
thanks for your replayhttp://forum.allaboutcircuits.com/member.php?u=19834
cfoek
Joined Jan 16, 2010
8
what for a transistor before the relay ?? can you explain to me ?? can i connect direct from R2 to relay ?
and what q1 should i use ?
i use a 12V
what program that u use for drawing schematic ?
for c1,c3,c4,c6 that's a ceramic capacitor ?
i want to try your schematic of 2 555 because i have the parts ready
thanks
Wendy
Joined Mar 24, 2008
23,429
A 555 can handle 200ma of current, but a transistor can handle a lot more. It is to provide drive for the relay coil. Without knowing your relay I can't tell for certain what you need, but almost all high power transistors will work. Something like a TIP102 perhaps, or a 2N3055. I need more information to answer definitively.
What the capacitor is made out of (ceramic) isn't as important as its value. If you have 0.1µF ceramic capacitors they will work.
I use M/S Paint along with a set of template I call PaintCAD. You can download them at my blog here on AAC.
Bill's Index
Introduction and PaintCAD
You didn't say how you were powering this circuit. You may need a 220µF cap to filter the power supply.
cfoek
Joined Jan 16, 2010
8
the relay is dc 28v 10a
for powering i use transformer 220V - 12V 500 ma then brige dioda 2A then 1000uf 25V electrolyte then 7812 and the last one ceramic 0.1uf, what did you think ?
if i want to change the delay from 3 second to 5 second or more what resistor and capacitor need to be change ?
thanks
t06afre
Joined May 11, 2009
5,934
Hi Cfoek
You could also have done this with a small 8 pin microcontroller and a very few components. Microcontrollers have become a very useful tool for the hobbyist. And the cost of a small microcontroller is almost the same as 555 circuit.
Wendy
Joined Mar 24, 2008
23,429
Hi Cfoek
But the amount of work programing them is much greater, there is a significant learning curve (which I haven't climbed). Then there is the issue of programming them, a one time cost in hardware to interface with a µC, which is not included in your estimate.
There is a reason these parts are still popular.
That is the contact rating, I need the coil rating. How much current and voltage does it take to drive the coil? While I'm asking, what are you going to drive, a motor? What is its rating?
That sounds fine for powering the 555. They can only take 15V max. Don't exceed it.
thanks
If you look at the schematic I included the formula for just such a question.
t06afre
Joined May 11, 2009
5,934
I think the cost-benefit curve for say a PICKIT 2 quickly will point the correct way ;) But yes it will require some interest in learning the knowledge behind using them. And every hobbyist is free to use whatever kind of tool they are comfortable with. And build what they please
cfoek
Joined Jan 16, 2010
8
i use a relay for a switch by cable to other 555 monostable
the relay is 12vdc and don't say about the current
what i mean is the capacitor need to be change for delay 5 or more second before power on is the R2 C2 or R4 C5 ?
@ t06afre thanks for info but i need this for door bell protection ... so it will be a waste to use a microcontroller just be a door bell protector hahahah
t06afre
Joined May 11, 2009
5,934
A microcontroller is a piece of silicon just like some 555 circuits. It is just a tool. In my toolbox it is a tool I use then I find it convenient perhaps more frequent than other tools. Other may have a toolbox with different tool(s) they like to use.
Wendy
Joined Mar 24, 2008
23,429
That and electrically µC are very simple on the outside. Simpler than two 555's by far, it's only a 8 pin package similar to a 555 package. Their complexity is writing code for them. There is a reason they exist too.
I would recommend anyone learn these suckers, they are very open ended. They do take some serious study to learn though, but in the long run it is worth it. They are a computer in a chip, and can do some nice logic tricks.
You wanted two delays, one is the one after the button is pushed, the second is how long the relay stays active. The first timer has the math for it included, as does the second. Without a schematic we're talking across each other.
