Prototyping RF
PRS
Joined Aug 24, 2008
989
Recent experience makes me think that breadboarding is not a good method for any rf circuit. I built an IF stage on a breadboard which I had designed and built in 1991. Back then it worked fine. This time it got a gain of only 6 volts per volt on the breadboard. I built it on etched copper clad and got a gain of 72! Which is what it should have been in the first place.
This makes me think that for rf, anyway, a design on paper should be at least dead-bugged on copper clad board before making any conclusions about its merits or demerits. Breadboards are unreliable. Any thoughts?
PRS
Joined Aug 24, 2008
989
Hey, thanks, Bertus, this is great! Making copper strips and pads that can be glued to a board leaves much to the imagination. Thanks!
Here's a confession. When I first started prototyping, I was afraid of using etching techniques because of my own ignorance. So I created my own way of using copper clad boards. This involved cutting the copper with a knife into 'pads' then soldering the components to those pads. But both this and the etched board methods mean you already have to have designed the circuit right. The dead bug and Manhattan methods make for ease of redesign.
And, along this line of thought, I recently read from the ARRL Handbook of a design that was first dead bugged and then turned into an etched board. It seems from this that ugly construction is best for rf prototyping.
k7elp60
Joined Nov 4, 2008
562
If you have want to make isolated pads on a piece copper clad board, I use this technique. I use a pen knife to cut the area I want to remove. Sometimes you can peel the area off once you have loosened part of the foil. On tough boards I heat the area to be removed with a soldering iron. This helps to peel of the area.
radiohead
Joined May 28, 2009
514
won't clad pads glued to a copper plane act as a (low value) capacitor? (probably minimal as compared to a breadboard, though).
PRS
Joined Aug 24, 2008
989
This sounds pretty much like what I used to do, but without the heat. I'll experiment with heat. Thanks! :)
PRS
Joined Aug 24, 2008
989
What you say here makes, sense, radiohead. I should think the method is limited to rf below UHF, maybe even lower.
Wendy
Joined Mar 24, 2008
23,429
If it is for power supply taps this can be a good thing, otherwise use point to point wiring. I've many a fine oscillator that was meant to be an amplifier.
