All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-15-2010, 02:22 AM
hockeyshot hockeyshot is offline
Default Circuit Board Push To Talk Walkie Talkie Headset
First off I am new to electronics, especially circuit boards so I dont know all the terminology; but i'm learning as I go along. Ill keep this short as possible and get straight to the point. I will admit, I did get over my head and as much as I don't like asking for help; I will be mature and ask for help which is why I am here. And for anybody who is wondering why I did this; it's because I do undercover work and needed a remote switch so I wouldn't stick out like a sore thumb when I pull out my headset to press the switch to activate the mic. And my boss is cheap and with that being said, I couldn't find any professional made accessories.
I took apart a headset for a walkie talkie. More specifically where the mic, push to talk button and the switch to select between push to talk for voice activation. I disconnected the momentary switch for the button when the you press it to activate the mic when the headset is in PTT (Push to talk) mode so I could extend the switch and activate my mic from the switch that I extended. I was trying to go for the secret service idea. Everything worked fine for me. Then I got more into the project and cut all into my wire (big mistake). So now I have one long wire that has the 2.5mm plug at the end(its a 2.5mm NOT 3.5mm) with two different wires. One thin wire and one thick wire. The problem is that on the thick copper wire also has a smaller white conduit wire with copper inside the small wire. So now that I have everything torn apart which was a big mistake, I have no idea which wire to connect the ear phone to (the thin wire; the thick black wire; or the thin white wire thats inside the thick black wire). I just need to know which wire to connect it to so I can solder it on and then solder my wires back onto the board. I dont want to short circuit anything since the headset that I got will be plugged into a company radio. Ive tried looking everywhere for a wiring diagram of a walkie talkie headset so I could figure it out on my own; but I must not be searching for the correct criteria since I can't find what I am looking for
I attached two drawing I made to the best of my ability using Microsoft Paint. Hopefully it will aid in the understanding of how my board is laid out and the head on view of the wire that has the 2.5mm plug attached.
Thanks for the help
Tags
Related Site Pages
Section Title
Video Lecture System Connectivity - Electronic Systems
Textbook Wiring Color Codes : Color Codes
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Setting up a home lab : Introduction
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help in designing LED automotive circuit board dlou87 General Electronics Chat 0 10-03-2006 08:20 PM
Sensor circuit, Flasher circuit 123456 Homework Help 11 08-03-2006 10:58 AM
the term "common" shelly50 General Electronics Chat 27 01-23-2006 04:02 AM
Circuit Board Night Vision crecencio General Electronics Chat 1 01-16-2006 03:04 AM
Circuit board Dan89 General Electronics Chat 0 05-15-2004 09:06 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
