All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-13-2010, 03:56 PM
QMcat QMcat is offline
Default cutoff frequency of a bandpass filter
a bandpass filter that build up by two simple a RC-lowpass and a CR-highpass in series. When combines those two, the highpass affect the lowpass and vice versa. how to calculate the both cutoff frequency?
  #2
Old 01-13-2010, 04:43 PM
Audioguru Audioguru is offline
Banned
Default
They combine to make a very poor filter because they are too simple. If the bandwidth is as narrow as is possible (the RC values are the same) then they attenuate everything including the frequency you want.
  #3
Old 01-13-2010, 04:50 PM
t06afre's Avatar
t06afre t06afre is offline
Default
You should also use a operational amplifier between the two sections. The two sections need to be "isolated" from each other
  #4
Old 01-13-2010, 05:02 PM
The Electrician The Electrician is offline
Default
You can do almost as well as using a buffer between the sections by scaling the impedances so that the second section doesn't load the first.
For example, if the first section consists of a 10k resistor and .01F cap, then make the second stage from a 100k resistor and .001μF cap.
Even then, it's not a very good filter. With only Rs and Cs, it's not possible to build a circuit with complex poles; all the poles are on the negative real axis, and good filters need complex poles (and zeros).
Tags
Related Site Pages
Section Title
Worksheet Switched capacitor circuitry
Worksheet Active filters
Worksheet Passive filter circuits
Textbook Resonant filters : Filters
Textbook Band-pass filters : Filters
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook High-pass filters : Filters
Textbook Low-pass filters : Filters
Textbook What is a filter? : Filters
Textbook Biasing techniques : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
cutoff frequency of a bandpass filter QMcat Homework Help 1 01-13-2010 11:25 PM
Need help with sallen key bandpass filter alialiali Homework Help 31 03-16-2009 07:10 PM
Sallen Key filter with different pole frequency? smokey General Electronics Chat 1 08-15-2008 12:17 AM
square wave -->sine using passive bandpass filter windell747 General Electronics Chat 2 06-22-2008 08:00 AM
Bandpass filter diwa2000@gmail.com General Electronics Chat 3 06-13-2008 02:35 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
