Possible to build my own wireless webcam?
holybrings
Joined Apr 4, 2007
64
Within 10 meters. Is it possible? It's for a mini lift project. The cam must be able to show the situation in the lift through wireless.
Wendy
Joined Mar 24, 2008
23,429
It is more than possible, but it would make much more sense to buy one. Better and cheaper, can't get better than that, all using off the shelf hardware.
Boo
Joined Oct 27, 2009
40
10M is within the range of bluetooth even, not sure if it exists though, but there are definately wireless cams available! This is definitely something you do not want to build yourself!
Fahad724
Joined May 10, 2013
Just connect the data end of the webcamUSB to a finished RF transmitter.Have its own receiver connected to the Comp.'s usb data pin.
30,821
Check out an automobile rear view (backup) monitor system, comes with wireless camera and LCD monitor. Don't know if it will work to 10m.
Markd77
Joined Sep 7, 2009
2,806
You could get a raspberry pi or similar with WIFI, and hook the webcam up to that. It would probably cost around the same as a wireless webcam (they seem pricey for what they are) but then you would have the raspberry pi for future projects.
