How to use a 8-bit multiplexer
yjpang84
Joined Sep 10, 2006
Guys im desperate..
this is the qn: Z is a boolean function of 3 input variables A,B and C. If A=C; else Z=0.
Design and draw a clearly labelled diagram to implement Z using only one 8-bit multiplexer.
i don't even understand the question. please enlighten. :confused:
thingmaker3
Joined May 16, 2005
5,083
What happened to "then?" Is the "then" supposed to be "Z=1?" Is B a "red herring" variable?
I would contact the instructor to see if there is a typo.
rishid
Joined Oct 24, 2005
8
Truth table for this is:
A B C | Z
0 0 0 | 1
0 0 1 | 0
0 1 0 | 1
0 1 1 | 0
1 0 0 | 0
1 0 1 | 1
1 1 0 | 0
1 1 1 | 1
Then I think you just use A,B,C as the select bits in the 8bit mux and draw either 1 or 0's as in puts depedning on the value of Z for the specific mux input
hgmjr
Joined Jan 28, 2005
9,027
I think you are going to need to incorporate a 4-input "OR" gate into which you will need to feed the appropriate outputs of the mux to complete the implementation.
hgmjr
Papabravo
Joined Feb 24, 2006
21,227
No need for the 4-input gate. The single output of the mux is all you need. The select inputs A, B, and C "select" one of the constant inputs to route to the output. It could hardly be simpler.
hgmjr
Joined Jan 28, 2005
9,027
My bad. Papabravo is correct. I was thinking of 3-in / 1-of-8 out decoder when I recommended an OR gate.
hgmjr
Papabravo
Joined Feb 24, 2006
21,227
It's an easy mistake to make without a diagram. Although I have known about this technique since I was an undergraduate, I have never had occasion to use it in a career that has spanned nearly four decades.
