All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-09-2010, 11:17 AM
sparkfishes's Avatar
sparkfishes sparkfishes is offline
Junior Member
Location: Burntwood, Staffordshire , England. ( Time Zone GMT )
Default Changing the range of an Unknown Ammeter
I have read the tutorial - to refresh my memory-
I have several small ammeters but want one to indicate
say 0- 5A or 0- 3 amps
However, I have a 0-10A and so can not make it read lower(?)
I have a 50mA which, by the addition of a resistor in parallel (1/10 of value as the resistance of the FS defelctionof the meter - I will check the maths after ) could get the ammeter to read ten times the shown scale .
My problem is the meter does not show the FS deflection resistance so how do I find that out?
Or any other solutions please!
  #2
Old 01-09-2010, 12:33 PM
Mike33 Mike33 is offline
Default
You need the current that will cause full-scale deflection. I wire up a 1M pot as variable resistance in series with the meter and an ammeter (DMM), then run a volt or 2 in and take the reading that gives FS.
You now have the meter's FS deflection in mA. This is probably what you were after...
Then I measure the internal resistance of the meter to get Rmeter, then use the formula:
Rshunt = Rmeter/N-1
where N= your desired FS deflection reading.
Real example:
Say you have a FS deflection of the meter at 1mA, and want a 5A FS meter, taking the meter's internal resistance of 58ohms (which I measured on mine), then the shunt resistor Rshunt=(58/5,000mA-1)= .0116ohms
You can get that value resistor using special-order shunts, or using resistance wire...make sure it can handle the additional current! :o)
  #3
Old 01-10-2010, 01:09 AM
someonesdad someonesdad is offline
Default
Quote:
It may have an internal shunt to make it a 10 A meter. You may be able to open the meter up and remove the shunt; then you'll have a meter movement that probably has a 50 μA or 100 μA or somesuch. Then you can make new shunts.
A useful number to remember is that 10 gauge (AWG) copper wire has a resistance of about 1 mΩ/ft; that may be helpful to make a shunt.
Tags
Related Site Pages
Section Title
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Worksheet Ammeter design
Worksheet Voltmeter design
Textbook Make your own multimeter : Dc Circuits
Textbook Ohmmeter design : Dc Metering Circuits
Textbook Multimeters : Dc Metering Circuits
Textbook Ammeter impact on measured circuit : Dc Metering Circuits
Textbook Ammeter design : Dc Metering Circuits
Textbook Voltmeter design : Dc Metering Circuits
Textbook What is a meter? : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
No current through ammeter in simple battery circuit GreenPenInc The Projects Forum 10 01-11-2010 01:29 AM
Type of switch used in multi-range ammeter jasonosaj Homework Help 1 12-23-2009 11:27 PM
Ammeter current meter to track down shorts relicmarks General Electronics Chat 9 11-15-2008 03:18 AM
voltmeter and ammeter i2me General Electronics Chat 0 08-05-2008 06:27 AM
PWM with options for changing dutycycle & frequency karunanithi_pricol The Projects Forum 0 08-22-2006 06:53 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
