All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Radio and Communications
Notices
Radio and Communications Discussion forum for all aspects of RF and communication engineering, including antennas, modulation regimes, RF circuits and filter design, and telematics.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-08-2010, 09:42 PM
PRS's Avatar
PRS PRS is offline
Default Why dB or dBm vs Volt/Volt?
I do not understand why matching resistances is so important in rf applications. Why not just consider each function as a module and give it high Rin and low Rout? By function, I mean such systems as an audio amp, an if amp, an rf amp. I'll sure appreciate your input.
Also, I worked briefly for a company that made frequency synthesizers. We used dBm there. Why not dB? Why not gain expressed in V/V?
__________________
Paul
Yakima, Washington
  #2
Old 01-09-2010, 06:16 PM
rjenkins rjenkins is offline
Default
Transmission lines need matched source and load resistance to avoid signal reflections from the line ends.
When cables or connections are a miniscule fraction of a wavelength (as in audio), most consumer manufacturors don't bother (though professional audio gear tends to be matched at 600 Ohm, as do telephone lines which can be rather long).
As the cable or transmission line gets to a significant part of a wavelength, mismatches cause signal distortion an possibly corruption. Take a look at the termination and matching requirements for the SCSI bus system for an example.
At RF, mismatches cause standing waves on cables which can cause extreme problems and damage equipment.
Another reason for matching is down to power transfer efficiency:
Imagine two resistors connected in series from a signal source to ground; the first from the signal is the source resistance, the second, to ground, the terminating resistor.
For any given signal level or voltage, the maximum *power* transfer (as in V * I) to the load resistor happens when the load impedance is equal to the source impedance.
__________________
Robert Jenkins.
  #3
Old 01-09-2010, 06:18 PM
bertus's Avatar
bertus bertus is offline
Administrator
Default
hello,
Take a look at this page:
http://www.educypedia.be/electronics/decibels.htm
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #4
Old 01-09-2010, 10:14 PM
PRS's Avatar
PRS PRS is offline
Default
Thank you very much for this reply to my inquiry. I've understood the maximum power transfer stuff, but not the SWR. I'll let you know what I am doing that brought this up: I'm designing and building a 455KHz IF amplifier as a generic lab module. From what you said, I should have an input impedance of 50 ohms and an output impedance of 600 ohms.
The rf amp and mixer feeding this IF amp should have an output impedance of 50 ohms and the detector and audio amp should have an input impedance of 600 ohms. Is this right?
To get the 50 ohm input impedance to the first IF stage we have a CE amp with an input impedance of 2.5 Kohm at 1 mA. Then probably about 2.2Kohm with the base bias resistors included. To get a 50 ohm input I should then use a step up transformer such that this 2.2 kohm looks like 50 ohms to the input?
__________________
Paul
Yakima, Washington
  #5
Old 01-09-2010, 10:15 PM
PRS's Avatar
PRS PRS is offline
Default
Quote:
Originally Posted by bertus View Post
hello,
Greetings,
Bertus
Thanks, Bertus. That is an excellent link. I have added it to my favorites.
__________________
Paul
Yakima, Washington
  #6
Old 01-10-2010, 12:58 AM
someonesdad someonesdad is offline
Default
Quote:
dBm means a power ratio relative to 1 mW. You could certainly use dB also, but you just have to explicitly state what the ratio is referred to; otherwise, it's ambiguous.
And there's nothing wrong with expressing gain as a dimensionless number. Engineers and scientists who work with numbers that range over pretty big ranges often reduce the scale to a logarithmic one just to work with more "reasonably-sized" numbers. Besides power, voltage, and current ratios, earthquake magnitudes are another familiar logarithmic scale.
  #7
Old 01-10-2010, 09:08 AM
Default
PRS:
The simplest analogy for impedance mismatch or SWR is to imagine a single ripple travelling down a canal with perfectly parallel sides.
Any sudden change of width (= impedance) causes reflections which both affect the wave and bounce back toward the source.
If you have a good high frequency 'scope, you can build a simple time domain reflectometer; this is a great device to literally look at impedance along a transmission line. All it consists of is a medium frequency oscillator with a good buffer and a source resistor. I used a little crystal osc module with a built-in divider. Something with an output in the 10 - 100KHz range should be OK. As a buffer I used all the sections of a 74ALS244 in parallel, then a 50 ohm resistor from that to the output terminal (and plenty of decoupling on the 5V supply).
Put both the x10 scope probe and the cable (or string of cables) on the output terminal and you will see a graphical representation of impedance against time.
Back to your I.F. amp:
The stage input resistance is high enough so just putting a 51 Ohm resistor across the input and ground, then a cap to the base cct should give a decent match.
Typically, I.F. transformers are double wound and tapped, allowing matching via the transformer. If you want to use transformer matching rather than resistive, you want about 6:1 or so, as impedance ratio is the square of the turns ratio.
If the output is still RF, you could also use a tapped IF transformer to get an appropriate output impedance.
If it's audio, you could use a 600 Ohm audio transformer in the output stage, this has the advantage of eliminating the common ground and removing hum loops. The transformers from 56K PC modems are 600 Ohm and rated to stand some DC current, so they can be used directly in the collector circuit of an amp stage. These 56K modem transformers are cheap and readily available, or just use one from a scrap modem.
__________________
Robert Jenkins.
  #8
Old 01-11-2010, 06:25 PM
PRS's Avatar
PRS PRS is offline
Default
PRS:
Thanks for the advice, all of which seems sound. The 51 ohm resistor at the base of the first IF stage is just too simple to be real, but I'll try it. In matching the 2nd to the 1st and the 3rd to the 2nd stages I plan to use singly tuned transformers with some sort of matching network at the output for 50 ohms. Is this reasonable in your opinion or is there an easier or better way? Remember this is a general purpose amp for the lab.
Also, what is the easiest and most economical way to control the gain? I'd like to keep it simple with just 3 stages.
I sure appreciate your help. Thanks again for the advice you've given me so far.
__________________
Paul
Yakima, Washington
  #9
Old 01-14-2010, 07:28 PM
PRS's Avatar
PRS PRS is offline
Default
dataman, I sure appreciate your response. I can see I have some serious homework to do in order to really get a grip on this. Until getting into radio recently my whole approach to amplifiers was voltage gain rather than power gain. I was also blissfully ignorant of SWR, though I had encountered the term without actually worrying about it.
Thanks for the info.
__________________
Paul
Yakima, Washington
  #10
Old 01-22-2010, 06:23 PM
KL7AJ KL7AJ is offline
E-book Developer
Default
Hi Paul:
There are indeed some R.F. applications where maximum power transfer is not the main goal, in which case treating the generator as a voltage source makes sense. As long as the transmission line is less than about .1 wavelength, SWR is not particularly an issue. (I posted a rather lengthy treatise on AAC not long ago called, "SWR Meters Make You Stupid.")
As far as dB is concerned, when you're expressing very large power (or voltage) ratios, dB keeps the numbers more manageable. Also, it makes most calculatons a mere addition problem.
Ultimately, ALL dB measurements are power measurements, even if you're deriving them from VOLTAGE ratios. This is why, if you DO you voltage to calculate dB, it MUST be the same impedance on both sides. If you violate this rule, you can show that a step up transformer gives you POWER GAIN, which we know is impossible! So you're always safer dealing with power.
Eric
__________________
REAL men don't need voltmeters.
Tags
Related Site Pages
Section Title
Textbook Impedance transformation : Transmission Lines
Textbook Standing waves and resonance : Transmission Lines
Textbook ``Long'' and ``short'' transmission lines : Transmission Lines
Worksheet Impedance matching with transformers
Worksheet Decibel measurements
Textbook Special transformers and applications : Transformers
Textbook BJT quirks : Bipolar Junction Transistors
Textbook Attenuators : Amplifiers And Active Devices
Textbook Decibels : Amplifiers And Active Devices
Textbook Maximum Power Transfer Theorem : Dc Network Analysis
Similar Threads
Thread Thread Starter Forum Replies Last Post
Plot freq vs. dBm on computer PeteB The Projects Forum 5 10-11-2009 09:48 AM
db and dbm shahnawaz Radio and Communications 11 05-13-2009 08:23 PM
logs / dB James4553 Homework Help 7 10-27-2008 12:34 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
