All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-06-2010, 05:35 PM
zenite zenite is offline
Junior Member
Default how does this solar lamp work?
http://www.ikea.com/us/en/catalog/products/90154371
The product above from Ikea is a solar powered lamp. I am doing a project similar to this, using solar power to charge a battery. Can anyone guide me to what I need to know to build the circuit to charge NiMH batteries like the lamp from Ikea. The batteries are being charged and the lamps can still operate. From what I know, NiMH must be disconnected and placed into the charger to charge. So how can the batteries in the lamp get charged w/o removing it? I need a push in the right direction, totally clueless.
  #2
Old 01-06-2010, 05:45 PM
Junior Member
Default
Another question, I am looking into this company solar panels...
http://www.jethobby.com.sg/cgi-bin/e...cid=114&gid=25
I need 8-12V and 2A for my device. Which solar panels should I use? I read from another post about using current regulator to increase the current (maybe I misunderstand it), but is it possible to increase current? The panels only give 100mA, which is typical of most panels. Those that come close to my need are too heavy (3kg) for use (in my proj).
  #3
Old 01-06-2010, 07:58 PM
rjenkins rjenkins is offline
Default
Charging a battery while still in circuit is simple - it just means that the charger can supply more current than the battery is supplying to the load, so more power is going to the battery than is being taken out.
The little solar lamps can cheat, as the solar cells can not give enough power to ever overcharge and damage the battery.
They also sense the output from the solar cell and turn off the lamp once the solar cell starts to produce power, so most of the power goes in to the battery.
Higher power circuits need more complexity to regulate the solar panel output and protect the battery from overcharge.
You need solar panels that give rather more power than your device uses, if you also want to charge a battery so it can run at night.
Also, don't be taken in by 'ideal case' figures for solar panels; these are when the cells are at the perfect angle in full sunlight - in real world conditions, with changing angles and clouds, the typical output will likely be rather lower.
There is no regulator that will give more power out than in. You can increase current but at reduced voltage, or increase voltage at the cost of current, but the power will always be less due to efficiency losses in the conversion process.
__________________
Robert Jenkins.
  #4
Old 01-06-2010, 11:55 PM
Bernard's Avatar
Bernard Bernard is offline
Default
How many hours per day does your device operate? A 20W load seems trivial when operating from the mains , from batteries it's a big deal. A 20V open ckt, 5W panel at peak power puts out 370 mA, so need about 5 hr for one hr of 20W load, and that is 12:30 PM Tucson AZ, clear sky.
  #5
Old 01-07-2010, 01:20 PM
Junior Member
Default
my device will operate for (hopefully) 2-4 hours on battery before it goes flat.
How do I increase the current while decreasing the voltage? It might be useful for my device.
also, as long as current is flowing into my battery, the battery will be charged no matter how small the current is? So all I have to do is connect the solar panel output to the terminals of the battery, and the circuit board of my device to the terminals of the battery too to achieve what I mentioned in the earlier post? (charging the battery while the battery is being used to power up the device)
  #6
Old 01-07-2010, 03:08 PM
Bernard's Avatar
Default
Using 8 size D NiMH batteries you might operate for about 3 h @ 2 A load. It would take about two days to recharge with 5 W panel with no external load. A 20 W panel might be about right. Might consider SLA battery.
  #7
Old 01-07-2010, 07:22 PM
Default
Yes, as long as the solar panel is providing more power than the device uses, the battery will be charging to some extent.
Use a Switched mode voltage regulator such as a National Semiconductor 'Simple Switcher' IC to step the voltage down. If you go from eg. 12V input to 5V output, the current at the 12V side will be roughly half that at the 5V output.
Don't forget you need a diode or whatever between the solar cell and the battery so it can charge, but not drain power back from the battery when there is no light. (The solar panel may already include this).
__________________
Robert Jenkins.
  #8
Old 01-07-2010, 09:19 PM
Darren Holdstock Darren Holdstock is offline
Default
NiMH are trickier to charge than the old NiCads, which I guess is why battery chargers aren't as cheap as they used to be. And they're never quite the same again if they're discharged too low (I've been working on chargers recently, and today I finished building a precision battery flattener that discharges down to 1 V and no further. An odd but necessary item if one is validating chargers).
BatteryUniversity is the best resource I currently know of.
  #9
Old 01-07-2010, 09:44 PM
Default
The 1V discharge limit is the safe limit if discharging a battery pack; this is just to avoid the chance of a weak cell becoming reverse charged whilst other cells are still discharging.
Single cells can be safely discharged to zero - this is in fact a good way of rejuvinating both NiCD and NiMH cells that appear to have low capacity, just connect a 10 Ohm resistor across each cell and leave for a few days.
__________________
Robert Jenkins.
  #10
Old 01-09-2010, 04:24 PM
Bernard's Avatar
Default
Harbor Freight Tools has a 45W panel, controller & 2 5W flourescent lighst on sale for $199 US. Should give about 3A @ 14V , enough to operate device with a little left over for battery.
Tags
Related Site Pages
Section Title
Worksheet Batteries
Textbook Gas discharge tubes : Thyristors
Textbook The transistor as a switch : Junction Field-effect Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Practical considerations : Batteries And Power Systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to charge a laptop battery with a solar panel ? kbarb The Projects Forum 6 07-19-2009 03:00 AM
Signal injection with a LAMP or LED relicmarks General Electronics Chat 7 11-03-2008 01:44 AM
why my pic not work? Parinda Embedded Systems and Microcontrollers 0 06-02-2008 09:03 AM
A dark secret about my Indian Teachers. lg00111@yahoo.co.uk Feedback and Suggestions 15 05-17-2008 10:41 PM
Wiring Solar Cells Kefka666 The Projects Forum 1 05-03-2008 04:25 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
