All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-02-2010, 05:43 PM
EXG EXG is offline
Default Pioneer RT 1020L Reel to Reel Tape Recorder
Yes I still like to record on reel to reel. I have three of them,different models and they all work fine except for one. Model RT 1020L plays back just fine but it does not record. It receives the signal but does not record. The relays work. Any ideas on what could be the problem? It also does not erase. I would like to fix it myself. Thanks
E.X.G.
  #2
Old 01-02-2010, 05:45 PM
Dom Mancino's Avatar
Dom Mancino Dom Mancino is offline
Junior Member
Default
could it be the recording head is bad?
  #3
Old 01-02-2010, 05:50 PM
bertus's Avatar
bertus bertus is offline
Administrator
Default
Are there two heads in the tape recorder?
Of so, one is fed with a high frequency signal to "wipe" the tape, the other is used for recording (normaly the playback head).
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #4
Old 01-02-2010, 05:57 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Nice deck!
The first thing you'll need is a service manual.
You can download one for free here:
http://www.free-service-manuals.com/...Manual_L76822/
but you'll have to register.
Hopefully, it's just something in the recording head driver circuit, not the recording head itself.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 01-02-2010, 05:59 PM
EXG EXG is offline
Default
I thought of that Dom and you might be right. That would also go for the erase head I suppose. Do you know how to test them? I will try some electronic stores to see who sells tape recorder heads but first I will figure out how to test them. Thanks
E.X.G.
  #6
Old 01-02-2010, 06:18 PM
EXG EXG is offline
Default
There are three heads. The erase head, record head and playback head. I believe thats what they are. Thanks Bertus.
E.X.G
  #7
Old 01-02-2010, 06:37 PM
EXG EXG is offline
Default
Thanks Sgt Wookie. I am waiting for the manual. Yes it is a fine machine and I am glad you appreciate it. Hopefully the problem is easy to fix. The heads are not worn at all. On top of all that I will have some good reading material that will be very useful. Thanks
E.X.G.
  #8
Old 01-02-2010, 07:30 PM
SgtWookie's Avatar
Expert Member
Default
As you probably know, they introduced that model in 1973, and ceased production in 1978. That means the components are at least 32 years old. Your prime suspects will be electrolytic capacitors, as these will lose their dielectric as they age. Often, the electrolyte will leak out or simply dry up if the hermetic seal wasn't perfect.
Sometimes they'll blow up and spew their contents on surrounding circuitry. This happens if they've been sitting for a long time and their dielectric strength has weakened; then suddenly power is applied and the high current through the cap causes the electrolyte to boil, creating pressure inside the cap housing.
A good preventative measure is to replace all of the old electrolytic caps with fresh ones from a high-volume distributor, like Mouser, Digikey, Allied, etc.
Sometimes you can re-form old electrolytics, if the electrolyte hasn't leaked or dried out. I just replied to a thread about this yesterday, in this forum. That thread is here: http://forum.allaboutcircuits.com/sh...ad.php?t=32195
Old resistors are another problem. The old cylindrical brown-body carbon resistors have a tendency to change their resistance over time. I have a bunch of those kinds of resistors that were made in the 70's and early 80's; they were originally 1% tolerance, and many are not even close to what they should be. The newer carbon film type that look like little beige dumbbells seem to hold their values quite well. I have quite a few of these that are 15 or more years old, and are still well within their tolerance.
__________________
General info:
  #9
Old 01-02-2010, 08:40 PM
EXG EXG is offline
Default SgtWookie
Thanks. Always glad to read you responses. I got my first one in 1976 from a friend of mine that bought his while he was in Viet Nam. That one still works just fine and I still use it for various home musical recordings. On this model all the electrolitics look fine as if they were brand new but it does not change the fact that they are old. So now I have a fine repair project ahead of me. By the way the folks at free service manual asked me if I was serious. I said, Yes. I might just have to work on instinct and trial and error. Thanks
E.X.G.
  #10
Old 01-02-2010, 08:41 PM
VoodooMojo's Avatar
VoodooMojo VoodooMojo is offline
Default
do the erase heads pull out of the way on playback and then redeploy on record?
could be something in that assembly.
and does that model have playback in the reverse mode?
__________________
Tags
Related Site Pages
Section Title
Worksheet Memory devices
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
