simplifying karnaugh map expressions without using the maps?
Alex_is
Joined Dec 27, 2009
hi there.
i have exams soon an really need someone to explain something i think is difficult, but may be quite simple to someone else....basically i have to revise karnaugh maps...i get what they and how to plot them but say you are given a group of unsimplified expressions on paper, is it possible to work out the simplification without using the maps?
can anyone explain with an example maybe? thank you
Alex_is
Joined Dec 27, 2009
this kind of helped but im still unsure of how to simplify the sum of products expression by means of boolean algebra :(
Papabravo
Joined Feb 24, 2006
22,083
The way I always do it is to express product terms as a binary number. for example AB*CD = 1011, and ABD = 11x1 using the lower case x for the don't cares. If you place this representation of product terms one above the other then an interesting pattern emerges. Any pair of product terms that is identical with the exception of a single column can be replaced with an 'x'. For example
Rich (BB code):
ABCD* = 1110
ABCD  = 1111
becomes
ABC  = 111x
OR
ABC  = 111x
ABC* = 110x
becomes
AB  = 11xx
Get the idea? this is essentially an algebraic representation of the Karnaugh map except it works for any number of variables whereas the Karnaugh map becomes unwieldy at 5 or more variables.
Ratch
Joined Mar 20, 2007
1,070
Alex_is,
You have me confused. First you say you want to do it without K-maps, and then you say you want to revise the K-maps. Which is it?
Anyway I advise you not to abandon the K-maps, because they convey more information at a glance than any other method. If you must use Boolean algebra, such as on a test, solve the problem with K-maps first, and then you can see which terms can be combined or discarded algebraically. Shown below are lots of links that may be of assistance.
Ratch
Read the first two links below even if you don't read any others.
http://forum.allaboutcircuits.com/showthread.php?t=12279&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=27402&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=14279&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=14804&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=15687&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=15915&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=18967&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=21089&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=20992&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=22347&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=27049&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=28035&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=28127&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=28732&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=29088&highlight=karnaugh
http://forum.allaboutcircuits.com/showthread.php?t=30781&highlight=karnaugh
gtan
Joined Jan 4, 2010
I found this software Logic Minimizer. http://www.logicminimizer.com that allows you to simplify kmap expressions with and without kmaps. Without kmaps, it gives step by step instruction on simplifying using rules. It's the only one i found so far that does this.
Hope it helps :)
