All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-26-2009, 03:02 AM
Cajunbubba Cajunbubba is offline
Junior Member
Red face Greenhouse wiring
I am wiring up a greenhouse that we built. I have installed 2 - 20 amp GFCI breakers and will use 12 guage wires. Because everything is in conduit I am trying to minimize wires. Here are my circuits:
1- recepticles on a timer switch for grow lights (about 1000 watts)
2 -(a)Exhaust fan and shutter motoers on a thermostat and reosatat (about 500 watts) & (b)additional recelpticles for possible heating pads
I am in the process of planning my wire pulls. I am using 3 wires Black (hot), White (neutral), Green (ground).
Main conduit runs overhead and drops down to various recepticles and stuff.
I would like to splice off the green and whites and run down to the recepticle but not back up to the main conduit. The black will go down and back up. (hopefully I have painted a picture). My qusetion is this going to create an inbalance for mu GFCI?
  #2
Old 12-26-2009, 03:07 AM
Junior Member
Default further clearification
do my wires (pigtails included) need to be all the same to avoid imbalance?
  #3
Old 12-26-2009, 03:11 AM
lmartinez's Avatar
lmartinez lmartinez is offline
Default
Follow NEC 2008.
  #4
Old 12-26-2009, 03:36 AM
Junior Member
Default ??
Really did not answer my question.
  #5
Old 12-26-2009, 03:44 AM
lmartinez's Avatar
Default
A schematic might be of help............
  #6
Old 12-26-2009, 04:18 AM
Junior Member
Default I'll post one in 16 hours
I will post one in 16 hours
  #7
Old 12-26-2009, 06:15 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
I really don't like to be critical, but...
Your project really requires the on-site scruitiny of a professional electrician.
I am NOT a professional electrician.
Furthermore, no professional electrician worth his or her salt would be able to give you proper advice remotely.
You need a professional electrician to look at your requirements and to keep you safe.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #8
Old 12-26-2009, 02:24 PM
Junior Member
Default
ok here is a basic view of what I want to to do. These are single 12 gauge wires. Seeing that I am proposing different lengths and junction points will this cause problems with my 20 AMP GFCI?
  #9
Old 12-26-2009, 03:30 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
The GFI is basically a circuit hanging off your wiring, it shouldn't have a problem, as long as you aren't trying to use it to feed the other circuitry. If you are, don't. Use a GFI as if it were an outlet for each outlet.
This is the image you posted, cropped to fit.
You should also be aware which pin is hot, and which is neutral, it is important.
For what it's worth, I agree with Wookie completely, this is not a job for an amateur.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #10
Old 12-26-2009, 03:38 PM
jpanhalt jpanhalt is offline
E-book Developer
Default
One thing to consider is how you are going to tap into the neutral and ground, if that is really what you mean to do. Remember that such taps must be in an accessible box.
Many electricians will simply run all three wires to the receptacle box (use a sufficiently large one) and make the taps or pigtails there. Be sure to consider that the box, if metallic, will also need to be grounded.
John
Tags
Related Site Pages
Section Title
Worksheet Mutual inductance
Worksheet Safety grounding
Textbook Wiring Color Codes : Color Codes
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Setting up a home lab : Introduction
Textbook Safe circuit design : Electrical Safety
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wiring of Inverter/Home UPS mmodi General Electronics Chat 13 04-13-2013 05:09 PM
12v Wiring Project Please Help. mplayerpro The Projects Forum 4 06-02-2009 04:26 PM
Wiring for a model railway single slip mikeandnel The Projects Forum 16 05-25-2009 06:58 PM
50 solar cell battery charger wiring? usrmpz The Projects Forum 5 05-16-2009 03:32 AM
Parallel wiring problem chris311 General Electronics Chat 8 03-21-2009 04:38 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
