All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-22-2009, 09:50 PM
ElectroFrog ElectroFrog is offline
Default Full wave 3 phase rectifier
Here's a scenario:
You have a 3 phase full wave power rectifier with one SCR open circuited (not firing).
What is the effect on the load?
Is it possible that this condition would cause abnormal heat buildup if the load was a battery being charged?
I'm also trying to understand the current flow - current rating relationship of the components. For example, we are using 3500amp SCRs w/ 4000 amp fuses on a piece of equipment that will conduct 8000+ amps (electroplating). How would I determine what current rating is required based on total current draw?
Thanks!
  #2
Old 12-22-2009, 11:06 PM
Duane P Wetick Duane P Wetick is offline
Default
It would seem like you have gone from a 3 phase FWB rectifier to a single phase FWB. You should have a reduction in output voltage to about 73% of normal with a correspondingly lower current (If the load is unchanged). Your plating solution determines your current draw, correct? Take some voltage readings and give us some data to look at, as I'm just giving you an educated guess.
Last edited by Duane P Wetick; 12-23-2009 at 02:20 AM. Reason: Error in computation
  #3
Old 12-23-2009, 12:21 AM
BillB3857's Avatar
BillB3857 BillB3857 is offline
Default
I doubt seriously that you would see a 73% reduction in output with one of 6 SCRs not firing. The SCRs are fired in pairs so you would only loose, at most, 1/3 of your output. In a plating operation, the ideal situation is to have a very smooth current supply, otherwise, whiskers and other bad things happen to the finish, if I recall properly. As for using the source as a battery charger, again, there would be a reduction of current every 120 degrees of your input frequency. Draw out your normal 3 phase rectified ripple signal then eleminate every third bump and you can see the effect.
  #4
Old 12-23-2009, 11:41 AM
BillB3857's Avatar
Default
Here are two simulations. First with all 6 rectifiers in the circuit and the second with one missing. As it turns out, you would get 4 bumps, miss 2, then get four, etc. In my first post, I forgot about full wave giving double frequency on ripple.. Old age brain toot.
Tags
Related Site Pages
Section Title
Worksheet Thyristor application circuits
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Video Lecture Power Supplies - Applications - Diodes and Diode Circuits
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with 3 phase and 6 phase half wave rectifier darthfader Homework Help 1 12-19-2009 07:01 AM
Full Wave Vs. Half Wave Rectifier at Small Voltages rperea General Electronics Chat 5 07-26-2009 09:07 PM
A Full wave precision rectifier query trytolearn General Electronics Chat 14 02-12-2009 04:51 PM
Full wave rectifier xpert General Electronics Chat 1 10-21-2008 01:25 PM
Power Engineering Help (Star-Delta) mksa Homework Help 2 05-09-2006 05:41 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
