All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-20-2009, 07:31 PM
pothineniuk pothineniuk is offline
Default what is the maximum allowed alternator voltage?
Today I took my Ford focus car to garrage for servicing and MOT. The guy told me that the alternator needs to be replaced as it is producing 14.9 volts power. Do we have any upper limit for the voltage?
Could anyone suggest me if it really needs to be changed? as it costs more than £150?
Thanks for the help.
Babu
  #2
Old 12-20-2009, 07:44 PM
eng1ne eng1ne is offline
Member
Default
Check this article:
http://www.carbasics.co.uk/How_to_te...alternator.htm
  #3
Old 12-20-2009, 08:09 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
14.9v is quite high. I would check the battery voltage after the car has been sitting with the engine off for at least 4 hours. It should measure about 12.7v to 12.9v when fully charged.
£150 sounds about the going rate for an alternator replaced by a mechanic.
However, if you are handy with tools, it is not very difficult to replace the regulator module in the alternator. It is much less expensive if you do it yourself; I'd guess you could fix it for about £10 if you already have the tools. However, I have no idea how mechanically inclined you might be.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #4
Old 12-21-2009, 04:19 PM
THE_RB's Avatar
THE_RB THE_RB is offline
Default
A lot of the newer alternators especially on smaller cheaper cars have the regulator integral to the alternator. It's not always replaceable. Sometimes riveted in, some are even molded into the endcap of the alternator.
__________________
Roman Black - PICs and electronics. Author of BTc PIC-sound encoder, Shift1-LCD project, the TalkBotBrain talking PIC controller, LiniStepper open-source microstepping motor driver, the Black Regulator 2-transistor SMPS, and probably some other stuff; www.RomanBlack.com
  #5
Old 12-21-2009, 05:22 PM
Default Thanks for the useful advise.
  #6
Old 12-21-2009, 05:47 PM
CarlM123456 CarlM123456 is offline
Junior Member
Default
Maybe this will help
http://www.homepower.com/search/resu...horname=&issue=
  #7
Old 12-21-2009, 06:43 PM
SgtWookie's Avatar
Expert Member
Default
Here is a thread on another forum directly related to alternator problems in the Ford Focus:
http://autoforums.carjunky.com/Autom...placed_P34404/
It appears from statements made in the thread that the alternator output is controlled by "a computer", not a regulator internal to the alternator. What computer this might be was not explained.
I don't know; I've never worked on a Ford Focus.
__________________
General info:
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Circuit to find maximum of three binary numbers? Blackrobe Homework Help 2 10-31-2009 12:35 AM
E-book Correction Error in Maximum Power Transfer Theorem page Ray A. Rayburn Feedback and Suggestions 27 09-01-2009 08:53 PM
Maximum power transfer chadchoud Homework Help 6 02-08-2009 12:24 PM
Maximum power transfer theorem??? dogar sahab General Electronics Chat 3 09-08-2008 02:17 PM
How to find the Maximum EIDE Drive Capacity for Motherboards GPSIM Computing and Networks 3 08-26-2008 10:31 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
