All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-07-2009, 09:31 PM
mcgregor.1 mcgregor.1 is offline
Default 2 stage transistor amplifier
I need help designing a two stage voltage transistor amplifier with a gain of 30. I already have the first stage worked out for a gain of 5, is it right that I just use the same calculations to calculate the 2nd stage for a gain of 6. ??
When I have tried it the gain on the 1st stage drops, is there a way I can calculate the voltage drop. ?
  #2
Old 12-08-2009, 02:10 AM
mik3's Avatar
mik3 mik3 is offline
Default
Post the circuit and your calculations.
Which gain are you talking about, voltage or current gain?
What is this amplifier for?
  #3
Old 12-08-2009, 06:49 PM
Default
It's a voltage amplifier, it's a project for uni.
Calculations
Chose Ic 1mV
Ve= 10% of VCC
R4= Ve/Ic =900Ω
R3= Vcc/2*Ic= 4.5K
R2= 10*Re=9K
R1=Vcc-(Ve+0.7)/Ve+0.7 * R2 =9KΩ
Used the same calculations for 2nd stage but to calculate R8 I used R3/R4 to get the gain of 6
  #4
Old 12-09-2009, 12:45 AM
mik3's Avatar
Default
When you derive the AC model of the circuit to calculate the gain of the first stage you have to consider the total input impedance of the second stage in your calculations. Thus, in this case consider R3//R5//R6//β*R8 to calculate the gain of the first stage.
β is the beta of U2
You have to consider the total input impedance of the second stage because it loads the first stage and voltage is dropped across the output impedance of the first stage and thus the output voltage of the first stage drops.
Tags
Related Site Pages
Section Title
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Active loads in amplifier circuits
Worksheet BJT amplifier troubleshooting
Worksheet Design Project: Audio power amplifier
Worksheet Class A BJT amplifiers
Textbook Feedback : Bipolar Junction Transistors
Textbook The cascode amplifier : Bipolar Junction Transistors
Textbook The common-collector amplifier : Bipolar Junction Transistors
Textbook Multi-stage amplifier : Discrete Semiconductor Circuits
Textbook Amplifier gain : Amplifiers And Active Devices
Similar Threads
Thread Thread Starter Forum Replies Last Post
Two stage timer. Need advice. Airasolt The Projects Forum 2 09-10-2009 12:15 PM
Two Stage Common-Emitter BJT amplifier Petrucciowns Homework Help 44 07-17-2009 10:33 AM
Expanding a 16 stage Sequencer to a 24 stage Habinh The Projects Forum 1 01-28-2009 12:42 PM
Trouble with trying to make a two stage amplifier :( sitech The Projects Forum 17 07-27-2008 07:27 PM
LARGE 12 & 14 volt 3 stage charger with a twist.... Dan. General Electronics Chat 0 04-17-2008 11:39 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
