Solve for P
spinnaker
Joined Oct 29, 2009
7,830
I swear every time I get away from basic Algebra for a while I forget everything. Boy do I feel dense! :)
I have the following formula.
L = P * (P - 1)
But I want the formula so I can plug in L and get a value for P.
I kind of did it brute force and the best I could figure is that P = SQRT(L), then round up the result. But somehow I don't think that is exactly right.
Could someone please help me here? Please just don't give the answer show me how to factor it.
I think it is:
L= P^2 - P
but that is were I get stuck. Not sure how to proceed from there.
S_lannan
Joined Jun 20, 2007
246
from there use the quadratic formula
rearrange it so p^2 - p - l = 0
then apply the quadratic formula..
here's how wolfram alpha does it, in a different way
http://www.wolframalpha.com/input/?i=solve+p^2+-+p+%3D+l+for+p
spinnaker
Joined Oct 29, 2009
7,830
This is a really cool site!
What I don't understand is that it produces two results. The first one does not appear to be correct.
  • Mathematica form
Results:
BillO
Joined Nov 24, 2008
1,001
It has two values because L is a quadratic function of P. It is a property of all quadratic functions, defined over a domain of all R that there will be two values in the domain for every value in its range (except one, at the apex of the parabola. In this case when P=1/2 is the only time that L=-1/4).
Mathematically this is the correct solution, however, physically, only one solution may have meaning. Is this the whole problem or is part of something else?
BTW, haven’t seen you over at the 6502 forum in a little while.
syed_husain
Joined Aug 24, 2009
61
try it in this way:
p^2 - p = L
=> p^2 -2*0.5* p+0.5^2 -0.5^2=L
=>(p-0.5)^2= L+ 0.5^2
=>p= 0.5 ± √(L+0.5^2)
now u can plug in value of L to get value for p.
spinnaker
Joined Oct 29, 2009
7,830
It is for a Charileplexing calculator / designer I am working on.
Yes I was on the 6502 forum. I will be back! :)
