RF Signal Tracer Amplifier IC
eufaula1
Joined Mar 29, 2009
Can someone recommend an IC to use as a wide band amplifier in RF signal tracer? I need an amplification stage between the probe and the audio amp. I would need something in the range of 455 kHz to at least 110 Mhz.
Thanks,
Bill Shamblin
<snip>
bertus
Joined Apr 5, 2008
22,947
You could try some MMIC's.
Here is an overview for the MMIC's:
MMICs
Here is a datasheet for the MAR6.
Mar6 datasheet
Greetings,
Bertus
PS remove you e-mail adress, spambots will find it and start to spam you.
KL7AJ
Joined Nov 4, 2008
2,229
Thanks,
Bill Shamblin
<snip>
Here's a top secret trick for signal tracers. (Shhh...don't tell anyone!) The typical R.F. detector probe uses a germanium diode for the detector...you need about a quarter of a volt for this to conduct, so it's not all that sensitive. If you use a Schottkey (hot carrier) diode for the probe, there is NO forward voltage drop...and it is MUCH more sensitive. This alone could make your additional preamp unnecessary. :)
eric
eufaula1
Joined Mar 29, 2009
Thanks Bertus and KL7AJ. That sounds like a great idea about using the Schottkey. I will try it out.
Thanks,
Bill Shamblin
***The OP is reminded that posting his email is not quite the thing to do.***
