I need to reverse LDR !!
myamzen
Joined Apr 26, 2009
5
Hi everyone,
I am doing a light and motion sensor circuit for my final project.
I was only able to find an LDR that has less resistance as it's exposed
to light. However, I am trying to do the opposite. One way I thought
of was using an inverting op amp (which turned out to be a stupid idea :D )
Anyway, I am trying to get less resistance in the dark so my
LED's would light up the room!! I tried to connect two of my LDR's
in parallel and that did not work out T_T
SO, what do u think might do the trick?????
Thanks for helping me out :)
hgmjr
Joined Jan 28, 2005
9,027
If you post your present schematic, we can tell you how to rearrange the components to invert the sense of the LDR.
hgmjr
hobbyist
Joined Aug 10, 2008
892
Heres one idea for an inverter.
Light hits the LDR and as resistance gors down, transistor conducts heavily.
Turns off LED.
Light NOT presenrt on LDR then transistor shuts off and LED comes on with current suplied through it's resistor.
someonesdad
Joined Jul 7, 2009
1,583
In the attached picture, assume R0 = 1. Also assume that LDR = 1 when the room lights are on and 10 when the lights are off. Then, if V = 1, you'll get V0 is 1/2 when the room lights are on and 1/11 when the room lights are off.
So the lesson is to remember i = V/R. R is the independent variable (the LDR), so combine it with a voltage to get a current that has the behavior type you want. Then you can either use that current directly or convert it back to a voltage as I did in the picture by dropping it across R0.
KL7AJ
Joined Nov 4, 2008
2,229
Hi everyone,
Why was that a stupid idea?
hgmjr
Joined Jan 28, 2005
9,027
myamzen,
You could sure save us a lot of guesswork if you would provide us with a schematic of your original schematic.
hgmjr
Dragon Tamer
Joined Nov 20, 2009
One way you could try to make the circuit respond to the dark (remembering that you just can't change the way a part operates) try switching the photo sensor with the grounding resistor on the base (as it gets darker it keeps less current from going to ground). another relay effective circuit that I've used (I made an entire control system for a shoe box radio using this circuit multiplied several times), it uses a comparator to look at the reference voltage.
http://www.elecfree.com/electronic/...o-thermo-control-relay-switch-with-ic-741.jpg
One thing that I have found is that if you remove the relay, and use a single transistor (or darlington array) it works just as well and... IT'S QUIET!!! And it can handle pretty high currents (my 2N3904 NPN transistors stood up to 100mA of current without giving out) You can also use the two resistors that are before and after the transistor you can modify the voltage output of the transistor, remember the formula R1+R2=R total, V total/R total=I total, sence the current through the 2 resistors are the same the you just solve for I total x R(1 or 2 depending on the value you are looking for although the resistor twards the Vdd is the bes choice), this same formula applys to the non inverting input of the op-amp. (just remember that the op-amps output is high if the inverting input[-] is lower than the non-inverting input[+]), for my circuit I think I made a few changes. IMPORTANT!!! MAKE SURE YOU ADD CURRENT LIMITING RESISTORS ON THE NON INVERTING INPUT OF THE OP-AMP, EITHER POSITIVE OR NEGATIVE END, OTHERWISE YOU WILL BLOW THE LDR OR THE POT!!! Another note, the lower the pot value, the more sensitive the circuit will be. If you decide that you do want to use the relay make sure that you modify the voltage for the rated voltage of the relay.
