http://www.box.net/shared/a1tei1c4ku
Hi all,
My first post on this website. Looks like a great resource.
Started an Electrical Control Systems course in August and progressing steadily. One of the units we're studying at the moment is about diodes and it's discussing their applications. One such application is to prevent spiking. There is a diagram illustrating the principal of operation of this concept but as of yet I can't grasp it. I'm wondering does anyone know of any java videos or any type of videos that might illustrate this concept graphically that are available online?
Here's the text to go with:
It is sometimes necessary to limit the amount of voltage present in an electrical circuit. For example, if the dc voltage to a coil is switched OFF, a back EMF is produced due to electromagnetic induction as we discussed in Unit 1. This back EMF produces an arc at the contacts of the switch used to disconnect the coil.
If the high-voltage spike generated by switching an inductive device OFF is allowed to reach electronic components like a transistor, the transistor can be destroyed. The de-spiking diode in Diagram (a) protects the circuit from surge currents developed when the current flowing through an electromagnetic device is abruptly interrupted.
The diode is connected in reverse bias so that current from the supply passes through the coil when the switch is on.
When the circuit is switched off by, the magnetic field of the coil collapses, inducing a back EMF in the coil. This EMF causes a current to flow that passes through the diode and not through the opening contacts of the switch. No spark is produced, and the sensitive switch contacts switching the coil are protected against damage."
Hope to get a reply.
Hi all,
