All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-16-2009, 11:47 AM
kuxz2008 kuxz2008 is offline
Member
Default hex inverter
i would like to know is IC SN74F04 same as IC 74LS04 ?
does the above 2 ic uses same or different voltage?
and is there any similiar IC for L293D with the same function?
  #2
Old 11-16-2009, 01:35 PM
beenthere's Avatar
beenthere beenthere is offline
Default
It depends on how you define "same". The logic functions are identical. 74Fxx logic is long obsolete. It was designed to allow faster operation than 7400 logic, but uses a lot more power. It's also pretty noisy, as the output stages permit a bit of shoot-through when switching. a 74Fxx IC will use almost an order of magnitude more power than 74LSxx. They both run on 5 volts Vcc.
Get data sheets to see exact power and speed differences.
__________________
First comes the hardware, then the software.
  #3
Old 11-16-2009, 04:08 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Quote:
They both require +5v for Vcc. 4.5v is the absolute minimum, 5.5v the absolute maximum.
I don't know what you are planning on doing, except that it sounds like you may be attempting to construct an H-bridge out of inverter ICs.
You may find these pages helpful for hobby robotic H-bridge drivers:
http://www.solarbotics.net/library/circuits/driver.html
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
Tags
Related Site Pages
Section Title
Worksheet Boolean algebra
Worksheet Digital-to-Analog conversion
Worksheet Latch circuits
Worksheet Electromechanical relay logic
Worksheet CMOS logic gates
Worksheet TTL logic gates
Worksheet Summer and subtractor opamp circuits
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Bipolar junction transistors as switches
Textbook Parallel-in, parallel-out, universal shift register : Shift Registers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Will Reversed Polarities Kill An Inverter? Bill from Auss General Electronics Chat 6 06-18-2008 02:14 PM
Octal inverter markmc001 The Projects Forum 3 06-02-2008 06:42 PM
Half bridge inverter Marie The Projects Forum 2 05-15-2008 06:15 PM
resonat frequency formula for hex inverter oscillator robo5050 General Electronics Chat 1 12-07-2007 02:17 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
