All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-16-2009, 04:42 AM
raziiq raziiq is offline
Junior Member
Default Making an Electric Door Lock?
Hi there
I am very new to electronic projects. I am really interested in making my door an electric One. I mean i have got my room door which locks/unlocks with a key, but i want to lock/unlock this with my Computer.
I can do the programming part, but making the hardware is a problem for me. I need some guidelines on how to start doing this? DC Motors may be?
Its ok if i have to make the lock from the scratch.
Any Suggestions ??
  #2
Old 11-16-2009, 07:42 AM
jut's Avatar
jut jut is offline
Default
too start out, and to keep it simple, you may consider a solendoid implemented as an "external deadbolt".
  #3
Old 11-16-2009, 08:04 AM
Junior Member
Default
thanks for the reply, but that flied over my head. I just know the basics of Electronics, i am very new to all this stuff. Can you please give me a little detail about it?
  #4
Old 11-16-2009, 08:40 AM
jut's Avatar
jut jut is offline
Default
This is what I meant by external dead bolt (i don't know the actual name):
http://www.efanlock.com/files/Door_Bolt.jpg
A solenoid is a metal rod inside or outside of a coil of wire. When a voltage is applied to the coil, the rod is either flung out of the coil, or pulled in. It depends where the rod was to begin with. Door bells have solenoids to perform the whacking of a bell with the rod. Also relays have solenoids inside them. You can also make one yourself.
Anyways the solenoid could push or pull the rod (aka the dead bolt) in or out.
  #5
Old 11-16-2009, 09:21 AM
Junior Member
Default
thanks.
But the question is how to make this possible? Even if i get this kinda Door Bolt from somewhere, how can i make this door bolt move in or out?
  #6
Old 11-16-2009, 09:54 AM
jut's Avatar
jut jut is offline
Default
Use your imagination. Make sketches. Brainstorm. Nobody is going to give you the exact plans so you'll have to come up with the exact design on your own.
Do you have tools to fabricate your possible design?
You may consider finding an auto wreckage yard and tearing apart the electric door lock mechanism--it uses a solenoid most likely. See how it works, adapt it, or use it.
  #7
Old 11-16-2009, 10:04 AM
Junior Member
Default
Ya my imagination pushed me for this project thats why i am here to find help. I know this thing can be done, but how to do is a problem.
I was thinking of moving that Solid iron bar inside that lock up and down with some something (DC motor may be) but how is again a question.
Can you forward me to some project like this which can help me understand stuff
  #8
Old 11-16-2009, 10:09 AM
jut's Avatar
jut jut is offline
Default
i don't know of any specific projects. try googling for it.
with this forum, more often than not, you need to ask specific questions about stuff or else your questions will not get much response. people here don't want to engineer an entire solution for you, but they, and me, would happy happy to help you along the way.
  #9
Old 11-16-2009, 01:51 PM
BMorse's Avatar
BMorse BMorse is offline
Default
You will have to use a DC (+12 volts) solenoid or something that can be battery powered, since if it is powered off of the mains (AC), when you loose power you will be locked out of your room.... or a small stepper motor will also work, but it will have to overcome the fact that the deadbolt will be dragging on the surfaces creating more friction and possibly jamming the motor from moving......
So you have a few things to consider before starting out,
  1. Power requirement
  2. Wireless or wired control from PC
  3. Motor or solenoid (go here for solenoids or motors >> http://www.macmaster.com, and other sliding lock mechanisms)
  4. Should you integrate it to a keyed lock in case there is no power you will have a manual override.
  5. Sketch of what you want to do (Circuit would also help)
My .02
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
Tags
Related Site Pages
Section Title
Worksheet Protective relay circuits
Worksheet Latch circuits
Textbook Safe practices : Electrical Safety
Worksheet CMOS logic gates
Textbook Basic voltmeter use : Worksheet
Worksheet Phase-locked loops
Worksheet Lock-out / Tag-out
Worksheet Arc flash and arc blast
Worksheet Switches
Textbook Simple combination lock : Digital Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
making PWM speed controller for Electric bike CaptainPrice The Projects Forum 41 09-25-2009 08:09 PM
How does electricity actually work? Xartrix Physics 26 08-06-2009 09:52 PM
Electric Flux & Electric Field Lines Mazaag General Electronics Chat 7 07-28-2009 07:06 PM
Electrostatics - Electric Flux Density D Nirvana Physics 7 01-14-2009 10:34 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
