All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-13-2009, 06:52 AM
surfline surfline is offline
Junior Member
Default Triac &/OR SCR to control voltage?
I am curious about the capabilities of using a TRIAC or SCR in a circuit to convert AC voltage to a desired DC output voltage. For example, if our input is the 110VAC, 60HZ source from house, would it be possible to trigger / fire the pulse of the TRIAC or SCR at times where the 110VAC, 60HZ sin wave is just at a certain voltage level we want, for example 30 volts. So our TRIAC gate pulse would just fire (by a microcontroller ) when our 60hz sinusoid is at 30 volts in the cycle, for a very short pulse width. We would then send this possibly through a transformer and then bridge rectification and smoothing circuit. Could we get a clean 30V DC output from this method?
Also, couldn't we just eliminate the transformer? Do people ever use TRIAC's / SCR's as an alternative to transformers?
Thanks,
Surfline
  #2
Old 11-13-2009, 11:23 AM
Thav Thav is offline
Member
Default
It sounds like you want to take a slice of an AC waveform, like when the utility voltage passes between 25 and 35V you want the SCR to be on, right? Unfortunately you can't do that with SCRs. Once you fire an SCR (or TRIAC), they can't be turned off until their current has reached zero and tries to reverse.
http://www.allaboutcircuits.com/vol_3/chpt_7/5.html
You could try that with a FET or IGBT which are fully controllable devices. At that point however, you're better off making a modulated rectifier so you get good power factor.
You can use semiconductor devices to transform voltages (like that rectifier I mentioned above). This is the principle behind all switch mode power supplies. You still require an inductor that will be smaller than a transformer needed to do the same job, and you would lose line isolation.
  #3
Old 11-13-2009, 12:07 PM
beenthere's Avatar
beenthere beenthere is offline
Default
You can't safely use a circuit that is directly connected to the AC line. A transformer is necessary to provide isolation and a safer level of energy limiting.
I have seen big power supplies that used SCR's in the rectifier bridge. The internal circuitry controlled their conduction to establish a voltage on the filter capacitors just enough above the required voltage output that the pass transistors could run in saturation. This eliminated losses in those transistors.
__________________
First comes the hardware, then the software.
  #4
Old 11-13-2009, 03:02 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
In my opinion, connecting circuitry to the mains without a transformer, is both foolish and unsafe. It is also against the policy of this board to support a discussion of such circuits. That said, the big problem with using an SCR in any application, is that it is easy to trigger and hard to turn off. In order to turn it off the current must be reduced to a low value near zero by some external menas. A triac is easier because the AC waveform reduces the current to zero each half cycle.
__________________
We never have time to do it right,
But we always have time to do it over.
Tags
Related Site Pages
Section Title
Video Lecture Transformers (Part 1) - Inductors,Capacitors,Transformers
Worksheet Thyristors
Worksheet Thyristor application circuits
Worksheet Power conversion circuits
Worksheet Basic AC-DC power supplies
Worksheet Step-up, step-down, and isolation transformers
Textbook Optothyristors : Thyristors
Textbook The TRIAC : Thyristors
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Thyristors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triac Control Zenock General Electronics Chat 27 06-24-2009 02:57 AM
How do I control the primary voltage in a transformer? electronice123 The Projects Forum 8 06-07-2009 09:28 PM
Control unit to Convert DC 90 volts to constant voltage source of DC 45 Volts. johnraj General Electronics Chat 3 10-05-2008 05:22 PM
Treatise about Voltage Ratch Physics 100 05-18-2008 07:55 AM
voltage vs. frequency ledjr Homework Help 3 11-26-2004 02:08 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
