All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-13-2009, 03:40 AM
jeka616 jeka616 is offline
Send a message via ICQ to jeka616 Send a message via MSN to jeka616
Default Single phase series motor reversal
Hi all.
I got a "Naniwa" (chinese?) single phase series AC motor. I tried to reverse the rotor connections (brushes) as I figured out this is the way it is done in hand drill.
It is rated 220v/0.5 amps. I connect 2+5, 6+4, and connect 1,3 to 220v AC. Runs fine, 18,000rpm as stated.
The problem is, it runs fine in normal, but to reverse, I connect 2+6, 5+4, and 1,3 is 220v. It runs about 11,000 rpm, brushesh spark out , and gets warm soon.
My fear is , this is uni directional motor. Is there any way to change winding? I guess need to get my head around winding the motor...just don't have time. So previous experience is much appreciated..
There are 2 symmetrical stator windings, and one rotor with brushes.
  #2
Old 11-13-2009, 04:57 AM
CDRIVE's Avatar
CDRIVE CDRIVE is offline
Default
I must admit that this is odd. The two wires that are connected to the brushes should be capable of being swapped.
__________________
__________________________________________________ ___________________________
Disclaimer: Any information that I post is intended for educational purposes only. No warranty or liability is expressed or implied. Note: Working with household line voltages (Mains) can be dangerous. Proceed at your own risk!
  #3
Old 11-13-2009, 02:47 PM
Bernard's Avatar
Bernard Bernard is offline
Default
Probably brush allignment; for bi-directional rotation, brushes are in-line with commutator diameter.
  #4
Old 11-14-2009, 02:31 AM
CDRIVE's Avatar
Default
Quote:
I dismissed that thought but there doesn't seem to be any other obvious explanation. What was it that S. Holmes used to say....?
__________________
  #5
Old 11-14-2009, 05:48 AM
Default
good morning.
I was carefully monitoring the contact are of brushes , as soon as saw this problem. I'll try to file the brushes, so either direction the contact area is the same.
But...will this help? another question is, I don't have any cap hooked up into motor, should I put one? which contacts?
  #6
Old 11-14-2009, 01:59 PM
CDRIVE's Avatar
Default
Universal (Brush) Motors don't require Start Caps. They have very high stall torque. If you do find caps, they're usually very small disk caps, used to reduce RFI only.
__________________
  #7
Old 11-16-2009, 03:25 AM
Default
I've managed to hook up stators to 12 v DC, and the rotor to ~45v DC. Runs ok, can reverse by reversing rotor connections. But, power is sacrificed obviously..
the next step, is to connect all in series, and hook up to DC, see how it runs..
  #8
Old 11-16-2009, 04:06 AM
CDRIVE's Avatar
Default
Quote:
If it's a series motor I would expect the the stator and Armature windings to divide up the supply voltage as per the manufacturer's design . Why have you been applying 12V to the Stators and 45V to the Armature? This may be partially the source of your excessive sparking but not certain.
Why haven't you been running it like this to start with?
__________________
  #9
Old 11-16-2009, 05:17 AM
Default
I was testing at which current the stator windings start becoming warm, hooked up paralel to 12v DC, about 2.7A (a bit high for winded wire gauge), and in series connection almost draws 1.3A.
one thing I found out, is stator windings are ~3.6 Ohm each, and the rotor (single contact place) is ~28 Ohm some. So in series, much power will be dissipated by greater resistance, so staror should be ok.
the answer is, I was planning to have fixed connections on stator, and then remotely change rotor connections, to reverse with built relays with radio control.
I just thought about connecting stator and rotor in series to same supply source rather that separate. will try today.
  #10
Old 11-16-2009, 02:07 PM
CDRIVE's Avatar
Default
Well you could have tested reversing the armature leads with everything in series to start with. These motors are popular for their high stall torque and variable speed using PWM. The schematic that Sgt. Wookie drew for the Split Phase Motor thread can be adapted to your motor.
__________________
Tags
Related Site Pages
Section Title
Textbook Selsyn (synchro) motors : Ac Motors
Textbook Wound rotor induction motors : Ac Motors
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Reluctance motor : Ac Motors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Three Phase Heater on Single Phase? sparks325 General Electronics Chat 6 11-13-2009 06:48 PM
Hooking up three phase power that is only being used as single phase. Mark074 General Electronics Chat 14 05-02-2009 05:00 AM
480 volt single phase lighting Talmadge General Electronics Chat 2 12-21-2008 02:56 AM
figuring single phase loads on 3 phase transformer stevegarren General Electronics Chat 3 12-11-2008 03:09 AM
Power Engineering Help (Star-Delta) mksa Homework Help 2 05-09-2006 05:41 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
