All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-10-2009, 11:45 PM
Ronscott1 Ronscott1 is offline
Junior Member
Default Collector-emitter feedback bias Dc calculations help
I was given the problem for homework to design the values of Rc, Rb, and Re given the following specifications:
Vcc=9V
Vce at midpoint
Ic=1 mA
βdc=300
Using the guidelines for VDB from Albert Malvinos "Electronic Principles" I came up with:
Ve=0.1*Vcc
Ve=(0.1)(9V)
Ve=0.9V
Re=Ve/Ie Since Ie≈Ic
Re=0.9V/1mA
Re=900Ω
Rc=4Re
Rc=4(900Ω)
Rc=3.6kΩ
Rb= βdc(((Vcc-Vbe)/Ie)-Rc-Re)
Rb=300(((9V-0.7V)/1mA)-3.6kΩ-900Ω)
Rb=1.14MΩ
But when I plugged these numbers back into the equation
Ie=(Vcc-Vbe)/Rc+Re+Rb/βdc, I got Ie=1.8mA.
Is there something that I am doing wrong? How should I go about calculating these resistor values? Also are there any specific guidelines that I should follow?
Best,
Ron
  #2
Old 11-11-2009, 12:07 AM
hobbyist hobbyist is offline
Default
Are they the guidelines your suppose to use, or are they your choice to use?
  #3
Old 11-11-2009, 12:18 AM
ELECTRONERD's Avatar
ELECTRONERD ELECTRONERD is offline
Default
Your schematic diagram is rather strange, since Rb usually connects above Rc to the Vcc source. But, as you may have realized, they form a voltage divider when connected to the collector. A useful equation is that
Austin
  #4
Old 11-11-2009, 12:28 AM
Junior Member
Default
Hobbyist-
Those are the guidelines I chose to follow. There is just about no information in my textbook about this type of biasing, let alone there is not much information available on the web. I am not really sure what guidelines to use. I just could not find any except for voltage divider bias in my text. Do you know of any?
Austin- Ideally what should I try to bias the base around?
  #5
Old 11-11-2009, 12:37 AM
Default
Quote:
Originally Posted by Ronscott1 View Post
Hobbyist-
Ron, a good resource is our current AAC e-book. Just go under "Volume III Semiconductors" and scroll down to the BJT biasing calculations. When beginning to bias transistors, Ohm's Law is virtually the only technique necessary, besides understanding linear region, saturation, and gain. Using the formula I suggested, . That's a very small Ib current. By seeing the formula alone, you can see that Ic, Ib, and β are all related.
Austin
  #6
Old 11-11-2009, 01:06 AM
Default
It looked like in your equation, for RB value, you were using the full 9V. instead of the drop across RC.
I may be looking at your equation wrong. Though too.
Is imidpoint at collector with respect to emitter or at the collector with respect to ground? That's my main question.
  #7
Old 11-11-2009, 04:28 AM
t_n_k t_n_k is offline
Default
Hi Ron,
It's those wretched parentheses ....
  #8
Old 11-11-2009, 03:57 PM
Junior Member
Default
Thanks so much for your help guys. Hobbyist - I am pretty sure that midpoint is with respect to ground.
Best,
Ron
  #9
Old 11-11-2009, 05:12 PM
Audioguru Audioguru is offline
Banned
Default
Quote:
No.
That is the worst way to bias a transistor since the wide range of beta, the different base-emitter voltage and different temperature all determine its amount of needed base current.
When a single base resistor connects to the collector then it provides AC and DC negative feedback.
If the beta or temperature is high then the transistor tries to conduct more which reduces its collector voltage that reduces the base current. Then the transistor does not turn on too much. If the beta or temperature is low then the opposite happens and the transistor does not turn off too much.
  #10
Old 11-11-2009, 08:37 PM
Default
Best,
Ron
See post #7.
he confirms your answer of 1mA.
Tags
Related Site Pages
Section Title
Video Lecture Troubleshooting Transistor Circuits - Transistors and Transistor Circuits
Textbook BJT quirks : Bipolar Junction Transistors
Textbook Amplifier impedances : Bipolar Junction Transistors
Textbook Biasing calculations : Bipolar Junction Transistors
Textbook The cascode amplifier : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help Calculating Rb Collector Emitter Feedback Bias Ronscott1 General Electronics Chat 4 11-10-2009 02:57 AM
A PWM DC Fan controller with rpm feedback and automatic rpm control! kammenos The Projects Forum 4 08-18-2009 08:17 AM
DC to DC Isolation Fuzzy54 General Electronics Chat 6 08-05-2009 09:39 PM
Removing +8v bias from pulsed DC ceaman General Electronics Chat 6 07-05-2009 05:14 PM
Cascaded amplifier AF and bias calculations Mancho Homework Help 0 11-29-2008 09:28 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
