| Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help. |
Thread Tools | Display Modes |
#1
find V=?
#2
V of this node with respect to what node?
__________________
>> Troubleshooting is an art << http://www.youtube.com/watch?v=hC7KYbFBPHA http://www.youtube.com/watch?v=StNJlRTWs9k http://www.youtube.com/watch?v=j-4h3l9O4fc http://www.youtube.com/watch?v=E0jZJ...eature=related |
#4
The first thing to do is re-draw the circuit so you can understand it. V source on the left, + up. Next draw in elements closest to the source on the right, continue adding elements on right. Ignore the 50 ohm resistor, it will not be part of the problem. Solve network for current.
Cheers, DPW |
#5
you could also try solving this with the node-voltage method. set the node in the left side to be you're ground node, then the voltage you are looking for will be the voltage at the top node.
| Bookmarks |
| Tags |
| circuit, electric, problem |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| problem in driver circuit | qdhossain | General Electronics Chat | 3 | 07-31-2008 04:17 AM |
| Circuit problem, help please! | true bypass | General Electronics Chat | 12 | 05-19-2008 08:28 PM |
| electric motor problem | jammex | General Electronics Chat | 17 | 03-11-2007 06:26 AM |
| 3-way circuit power problem | Griffin | The Projects Forum | 6 | 01-16-2007 01:42 PM |
