All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-08-2009, 10:56 AM
mkbutan's Avatar
mkbutan mkbutan is offline
Member
Default Class of Tr. Amp.
what are the classes of Amplifier's (as CLASS A;B;C;D or x; etc.) how to classify the class of any Transistor Amplifier
(eg.:-to take any BJT transistor out there and bias it in order to make it a Class-A amplifier.) as in the thread ( http://forum.allaboutcircuits.com/sh...ad.php?t=29729 ) by Mr.Austin
__________________
"THE LIFE IS VERY SMALL TO LEARN ELECTRONICS"
ε∫εζτ√°ηiζ≈
  #2
Old 11-08-2009, 12:39 PM
hobbyist hobbyist is offline
Default
If your extrememly new to transistor amp design, then here is a very BASIC procedure.
Without getting into input and output impedances, but just to bias a transistor into its linear region, using a NPN transistor.
1. choose a resistor value for RC. (the resistor from collector to positive supply VCC.
2. Take half the supply voltage VCC. and divide this resistor into it, to give collector current. (IC)
3. Divide the RC value by 10 and use a resistor close to that value for the emitter resistor. RE.
4. multiply IC x RE to give a value of VE. (voltage at the emitter)
5. Add (VE + 0.7v.) to give voltage at the base (VB). (assuming a silicon transistor)
6. Put a resistor from ground to base that has a value of around 5- 20 times RE. (R1)
7. Take (VB / R1) to give divider current. (ID)
8. then {(VCC - VB) / ID} = the value for the top resistor from base to positive supply, use a resistor close to that value.
The most important part of this design is this,
prototype it (breadboard, or simulator), and check the voltage at the collector with respect to ground, you should have close to 1/2 VCC.
If it is too low, then the transistor is on too hard, so either decrease the bottom resistor, or raise the top resistor value. (of the divider)
If it is too high, then the transistor is not on hard enough, so either increase the bottom resistor, or decrease the top resistor value of the divider.
Adjust these values until you have close to half the supply voltage.
That is called quiescence state, which simply is linear mode (class A) of operation.
  #3
Old 11-08-2009, 12:57 PM
bertus's Avatar
bertus bertus is offline
Default
On this page from the EDUCYPEDIA, you will find a lot of links for amplifier classes:
http://www.educypedia.be/electronics...ierclasses.htm
Theory about amplifiers can be found here:
http://www.educypedia.be/electronics/amplifiers.htm
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.(User CP -> Edit Your Details)
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Class AB RF amp Regected The Projects Forum 5 09-21-2009 02:52 AM
Class A Amp Load and Bias Problem logans-electronics The Projects Forum 4 09-07-2009 04:38 AM
building a class AB amp jasnc2107 The Projects Forum 49 05-03-2009 10:02 PM
Class D amp -my working prototype RmACK The Projects Forum 11 07-25-2008 11:05 AM
the power amp class A,B,and AB flugman Homework Help 3 05-30-2008 10:03 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Copyright © 2009, All About Circuits. All Rights Reserved.
