All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-07-2009, 11:28 AM
gusmas's Avatar
gusmas gusmas is offline
Member
Default Servo motor prob
Ok nw i am using a tripple 5 timer to position the servo , they both get their supply voltages from the same source, nw when i remove the puls frm the servo it goes back to its default position and i dnt want that, bt ive noticed that if i jst removd the supplie voltage frm the servo and then after 1sec the i remove pulse then the servo stays in that position, so guys i need help, i want to remove the supply frm the servo and 555 at the same time, but i want a kind of delay on the 555 supply after i remove the supply, so fr example, b0th 555 timer and servo they share the same line for Vcc, when i remove the supply the servo mst be off bt the 555 mst still hve a supply fr lets say 0.5sec....
  #2
Old 11-07-2009, 12:18 PM
gusmas's Avatar
Member
Default
Ok i gt a solution, just a simple rc cct, wl that work?
  #3
Old 11-07-2009, 12:42 PM
BillB3857's Avatar
BillB3857 BillB3857 is offline
Default
A capacitor decoupled with a diode should do what you want. Feed power directly to servo and anode of diode, couple cathode side of diode to fairly large sized cap and feed 555 from cap. Resistor not needed. Cap size would depend upon current draw of your 555 circuit. Bigger cap = longer delay.
  #4
Old 11-08-2009, 05:59 AM
gusmas's Avatar
Member
Default
Ok i see, but the diode wil have a volt drop acros it so ill need to increase the supply?
  #5
Old 11-08-2009, 02:54 PM
BillB3857's Avatar
Default
The diode will only drop about 0.7 volts. If you need to have matched supply to the servo and the 555, simply put a diode in series with both. The cap across the 555 Vcc-Ground connection will keep the 555 pulsing after the power is disconnected. Again, how long the 555 will keep pulsing will depend upon the size of the cap.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
555 servo tester. What Pot? Fenris The Projects Forum 12 11-04-2009 08:54 AM
AC OR DC ? Servo help GARYN The Projects Forum 8 09-30-2009 03:44 PM
Servo input: PWM or analog lisandro The Projects Forum 2 10-30-2007 11:56 PM
Servo input: PWM or analog lisandro General Electronics Chat 1 10-30-2007 11:00 PM
Servo Motors Mazaag The Projects Forum 2 11-10-2006 08:18 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Copyright © 2009, All About Circuits. All Rights Reserved.
