Simple pulse counter and display using PIC 16F627
woodysgreen
Joined Nov 5, 2009
Hi guys, first time here
I have just had some work experience and have been asked to look at a counter which will display the amount of electricity used every minute. eg the counter will receive pulses from an electricity meter and after one minute display the count on a 3*7-segment display. The counter should then reset and begin counting the next minute with the display still holding the previous minutes count, after the next minute it should display the new count.
I have bought a PIC programmer and experiment board (K8048) with a PIC 16F627 and I'm trying to learn via modifying code to get the near the result. Could anybody give me some guidance as to how I set-up the counter and the minute timer.
Any help is much appreciated.
mik3
Joined Feb 4, 2008
4,843
Some of the internal timers of the PIC can be used as counters which can count external pulses. If non is able to do that use an input pin and increment a variable each time a pulse arrives. Use delay functions to create the one minute delay which will read the value from the counter or the variable and display it and restart the counting. If possible an interrupt can be triggered every minute instead of delays.
woodysgreen
Joined Nov 5, 2009
I'm trying the input pin and incrementing a variable. i'm determined to complete this at the weekend. Thanks for the reply mik3
woodysgreen
Joined Nov 5, 2009
Completely desperate.
Can anyboby give me a starting point with my problem. I have tried the incf command but can't even get my led's to count up in binary. I don't know where I'm going wrong.
COUNT EQU b'00000000'
SWITCH_1 BTFSC PORTA,0
GOTO ADD
GOTO SWITCH_1
ADD INCF COUNT,0
MOVWF PORTB
RETLW COUNT
END
mik3
Joined Feb 4, 2008
4,843
You have to create a loop for the whole program as to repeat again and again.
For example:
LOOP
GOTO ADD
GOTO SWITCH_1
ADD INCF COUNT,0
MOVWF PORTB
RETLW COUNT
GOTO LOOP
END
Markd77
Joined Sep 7, 2009
2,806
I think this might be what you are trying to do. You will find that this increases the counter very quickly all the time the button is pressed (or not pressed depending on the circuit) so some more code will be required to make it count once per press.
CALL ADD
GOTO SWITCH_1
ADD INCF COUNT,F
MOVF COUNT, W
MOVWF PORTB
RETURN
END
