All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-03-2009, 08:32 PM
markosillypig's Avatar
markosillypig markosillypig is offline
Default help determaning a transistor
h i am making this circuit i have altered it from the original one could any one tell me that i could use as Q1 to Q10 for 500 MA or above say 750MA and what the value of resistors i need for the Q1 to Q10
thanks
__________________
the brighter the led the better
  #2
Old 11-03-2009, 10:39 PM
mik3's Avatar
mik3 mik3 is offline
Default
What is the output voltage of U2 and how much current each output can source?
  #3
Old 11-03-2009, 10:53 PM
Default
4.95 volts x 500 MW if this helps
__________________
  #4
Old 11-03-2009, 11:12 PM
mik3's Avatar
Default
The maximum output current of U2 when it is power with 5V is 0.36 mA. Thus you will need a 12K resistor for each transistor. Also, you have to use darlington transistors which have a gain greater than 1500 at saturation.
  #5
Old 11-03-2009, 11:28 PM
Default
will a TIP23 do the job or can you recomend something else i have in stock some IRF530's
__________________
  #6
Old 11-03-2009, 11:36 PM
mik3's Avatar
Default
The IRF530 is not a logic level MOS. It needs 10V to fully turn on however you may use it because the current through it will be only 500mA. Try one and if it gets very hot then you have to use another one or power U2 with 10V.
I can't find TIP23.
  #7
Old 11-04-2009, 12:10 AM
Default
sorry tip32
__________________
  #8
Old 11-04-2009, 12:15 AM
mik3's Avatar
Default
Quote:
Originally Posted by markosillypig View Post
sorry tip32
Its gain its too low, you can't use it.
  #9
Old 11-04-2009, 12:17 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
You are going to need to use a different regulator than the 78L08 since it is only rated for 100 milliamps maximum.
hgmjr
  #10
Old 11-04-2009, 12:37 AM
Default
i have the 78l08 so i will replace it
__________________
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Copyright © 2009, All About Circuits. All Rights Reserved.
