All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-02-2009, 03:53 AM
pastaperson pastaperson is offline
Default Equation for capacitor discharge
I've got the following circuit here:
I want to find an equation to model the capacitor discharging. If I'm correct, this is the needed equation:
V = V0 * e^(-t/RC)
In my case, I am using a nine volt battery, 1K resistor and 5μF Capacitor. When I calculate the RC I get 0.064, which surely can't be right here?
I'm using Circuit Wizard, and this is the output of graph when it runs on the three probe points (as above):
Basically, when the equation for the capacitor discharges meets the equation of the voltage divider, the LED will turn off. I'm trying to find this equation so that I can include it in my write up.
Thanks for your help
- pasta
  #2
Old 11-02-2009, 05:11 AM
JoeJester's Avatar
JoeJester JoeJester is offline
Default
Visit http://www.allaboutcircuits.com/vol_1/chpt_16/4.html for more information.
Your image doesn't show a 9V discharge curve. The tau is only 5 milliseconds and the 9 V should have decreased to zero in about 25 milliseconds.
You might want to ensure you have a good discharge path.
__________________
Joe
http://www.fcctests.com
  #3
Old 11-02-2009, 05:32 AM
t_n_k t_n_k is offline
Default
Quote:
Yes indeed - the discharge path into the LM741 negative input will be of fairly high resistance. I doubt the 10k plays any significant part in the discharge time.
  #4
Old 11-02-2009, 05:34 AM
Default
Quote:
I mean the 1k - R10.
  #5
Old 11-02-2009, 05:42 AM
Default
In the interests of circuit predictability, the 1k should probably be in series with the switch to limit the current pulse magnitude drawn from the 9V supply when the switch is pressed - otherwise you have an effective momentary "short circuit" when C is even partially discharged.
  #6
Old 11-02-2009, 07:35 AM
Default
I've since fixed that. Its meant to act as a debounce, so I am pretty happy with the way it discharges.
What I'm confused with is 0.064 and why it isn't discharging correctly? I'm assuming the formula is correct here, but I'm missing something with my circuit?
When I graph 9 * e^(-1/0.064) over the domain [0, 1], I get the following image:
Which certainly fits what JoeJester was saying
  #7
Old 11-02-2009, 08:37 AM
Jony130 Jony130 is offline
Default
To proper "discharge" you need to add resistor parallel to C1 to get good discharge path.
Now capacitor is discharge by base current of LM741 and this current is very small typ. 20nA, max 200nA.
So to discharge 5uF capacitor to 0V you have to wait
C=Q/U=I*t/U
t=(C*U)/I=(5uF*9V)/200nA=225s
For example, if we have a capacitor charge to Vcc=9V and we wont to discharge capacitor to Vc=4.5V at time t=5s
We need parallel resistor R
R = t / ( C*In(Vcc/Vc) )
= 5s / ( 5uF * In(9/4.5) )= 5/(5uF*0.693)=5/3.465u=1.44MΩ=1.5MΩ
  #8
Old 11-02-2009, 03:56 PM
JoeJester's Avatar
Default
If you want the LED to energize when you press the switch and then de-energize after a delay when you release the switch, you might want to use the circuit illustrated in the 091101_B picture. 091101_A illustrates the waveforms.
If you want delay energizing the led, (less than one tau), then place the resistor in series with the switch.
The resistor placement in the OPs diagram is in series with the High-Z OPAMP input, making the discharge path the Input Z and the resitor.
__________________
Joe
Tags
Related Site Pages
Section Title
Video Lecture RC Time Constants (Part 1) - Pulse Circuit Response - Inductors,Capacitors,Transformers
Worksheet Timer circuits
Worksheet Time constant calculations
Worksheet Time constant circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Simple question on characteristic equation. MichealY General Electronics Chat 8 06-26-2009 03:18 AM
Need quick answer: Does POS simplify into equivalent SOP simplification equation? andrewle8 Homework Help 1 02-23-2009 08:26 PM
Hie im new . POTENTIAL DIVIDER EQUATION ..! Giggabyte General Electronics Chat 2 09-19-2008 01:17 PM
Have to make equation with given equation justinneedshelp Homework Help 5 11-08-2007 12:46 AM
Simultaneous Equation techniques Gears Math 7 03-18-2007 12:25 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
