All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-30-2009, 09:58 AM
Nashuan Nashuan is offline
Default how do I delay the start of this circuit?
Hey all. I posted this question in the general discussion area, but it may be better suited here. I'm hoping someone can help me with a small project I've been working on, but can't make progress with. I want to make a decade counter that won't turn on for 17.5 seconds. I'm interested in a design like this:
http://delabs-circuits.com/cirdir/theory/gates/doc00020.html
I've rigged 10 sets of 7-segment LED displays to show one digit each (each display will show one digit that is alsways the same - no need to encode/decode) and want to have them flash one at a time in place of the LEDs shown in the circuit: staying on for about 1/2 second each. The circuit will be powered by 5V DC and would be activated by a momentary pushbutton switch and I want the sequences to cycle over and over again until the voltage source is removed.
I contacted the designer of the above-listed circuit and he was kind enough to suggest that I try:
"use chip CD4541 for the 17.5 Sec delay
http://www.standardics.nxp.com/products/hef/datasheet/hef4541b.pdf
http://www.fairchildsemi.com/ds/CD%2FCD4541BC.pdf
See the drive circuit here http://www.acroname.com/robotics/info/articles/drivers/drivers.html
http://terpconnect.umd.edu/~toh/ElectroSim/relay.html "
I've purchased the CD4541 chips he mentioned, but am lost in how to hook one up to the circuit and to set the delay I need. Essentially, what I want is to use this circuit in a "geocache", where an audio recording begins and part-way through it, the sequencing of seven-segment displays give you your next set of longitude/latidude coordinates. For those who don't know what geocaching is, imagine a scavenger hunt where the goal is to find a hidden container using a handheld Global Positioning Device (more info is available at geocaching.com). Some of these geocaches have themes and this one will be related to a Boy Scout Merit Badge Series - the Electronic Merit badge. I am pretty new to the electronic scene, so what seems "obvious" to some people may not be to me, though I do have some background to work with.The person I contacted was nice enough to respond and try to help, but I don't want to keep bothering him. Does anyone want to try to help work this out?
Thanks,
Nashuan (Michael)
  #2
Old 10-30-2009, 08:08 PM
Bernard's Avatar
Bernard Bernard is offline
Default
If you are using 4017, use a second 555 { or one 556 ] as one shot with output,17.5 sec, connected to 4017 enable. Connect a small cap [ .1 ] to pin 2, 10k resistor pin 2 to +V to give a short delayed trigger at turn on. With a high on enable 4017 will be inhibited for 17.5 sec.
  #3
Old 11-06-2009, 08:40 AM
Default
Thank you Bernard. I'll give it a try. I have a really basic background in electronics, but a fascination with building little circuits. This is a streatch for my 'current' (no pun intended) abilities, but I've been working on it for months and would like to see it actually work for real sometime soon.
Tags
Related Site Pages
Section Title
Worksheet Shift registers
Worksheet Counters
Worksheet Digital display circuits
Worksheet CMOS logic gates
Video Lecture Asynchronous Counters - Digital
Textbook Asynchronous counters : Sequential Circuits Counters
Textbook Monostable multivibrators : Multivibrators
Textbook LED sequencer : Digital Integrated Circuits
Textbook NOR gate S-R latch : Digital Integrated Circuits
Textbook Time-delay relays : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
rc delay circuit hobeycat10 The Projects Forum 5 10-14-2009 06:56 PM
Delay Timer Circuit for Model Railway needed Imagineering The Projects Forum 4 12-05-2008 04:28 PM
Delay Circuit robby991 General Electronics Chat 30 04-08-2008 12:15 AM
Delay Circuit sorany The Projects Forum 13 03-30-2007 12:17 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
