All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-27-2009, 06:59 PM
bluebrakes's Avatar
bluebrakes bluebrakes is offline
Default high side/low side mosfet
I've generally got a good idea how mosfets work.
But i've got a couple of questions you've answered hundreds of times before and are getting sick of it.
What is high side and low side?
Unlike transistors that use current, mosfets are driven by voltage, so why do on a few schematics that i come accross, do they have the gate voltage side listed as 5v and the switch side as a higher voltage, such as 12v?
What do people use to drive the gate, if the only power supply is say 12v and the gate needs a minimum of 2v to close?
  #2
Old 10-27-2009, 08:25 PM
MikeML's Avatar
MikeML MikeML is online now
Default
The issue with a FET is not what is the minimum voltage that just barely begins turning it on, but how big the gate-source voltage needs to be to fully saturate the FET. Most FETs, even though they have threshold voltage of ~3V, really need a minimum of ~10V to get the advertised drain-source ON resistance, and low self-heating.
High side/Low side usually refers to where the FET is relative to the Load. If one end of the load is grounded, the switch is a HIGH-SIDE switch. If one end of the load is tied to Vcc, then the switch in series with it is a LOW_SIDE switch.
A FET can be configured as a switch, or as a source-follower, regardless of it being high-side or low-side. The gate drive direction and level is a function of the configuration. For example, if a high-side switch is configured as a source-follower, the gate should be driven about 10V more positive than where the drain is connected.
  #3
Old 10-30-2009, 08:23 PM
bluebrakes's Avatar
Default
ok I think i understand thanks.
So basically the high side refers to whether the mosfet is controlling the positive side or ground side?
I have another question...
As an experiment, I thought I would see how the mosfet would react at different gate voltages. I've used the IRF3205 to make a h-bridge to power a 360watt motor. I'm basically making a very powerful servo motor using an m51660l and it's working brilliantly. I've got my laptop controlling a PIC based servo controller, which then goes through the m51660l, then optcoupled with the h-bridge to drive the motor. Not being very experienced mosfets (why?! I never really bothered before when I could get away with your average transistor). So my question is, what should i use to drive the mosfets because currently i'm using an isolated power supply to drive the gates and I would like to use the same power supply as the h-bridge (12v).
BTW here were my findings from my experiment...
  #4
Old 10-30-2009, 08:52 PM
jpanhalt jpanhalt is offline
E-book Developer
Default
Your data don't make sense to me. The IRF3205 is an N-channel mosfet. If the gate is 10V(+/-) relative to the source, the mosfet should be fully turned on, and the source (if low side) should be near ground.
Can you post the circuit from which you made those measurements?
John
  #5
Old 10-30-2009, 09:18 PM
bluebrakes's Avatar
Default
This would be my circuit that i'm doing the test on. The two 10k resistors are to pull down the voltage on the gates, so they are open when they are supposed to be. I'm using a TTi PL330QMD power supply (as shown as batteries) to do the testing with and a fluke multimeter to check the output on the h-bridge.
  #6
Old 10-30-2009, 09:21 PM
bluebrakes's Avatar
Default
When I was using the bridge to power the motor as a servo, there didn't seem to be any problem (no heat, no current being used when not in use, etc). Also I have tried removing one of the resistors to see the effects, which were none at all. Although it does cause the mosfet to stay on when it should be off.
  #7
Old 10-30-2009, 09:29 PM
E-book Developer
Default
Look at it like this: When Q1 and Q4 turn on, the voltage drop across Q1 is very small, so its source is at roughly 12V relative to ground. If its gate is also at 12V relative to ground, it will no longer be turned on. The circuit will not work. However, you find that the circuit seems to work. Try putting the motor under full load.
John
  #8
Old 10-30-2009, 09:45 PM
bluebrakes's Avatar
Default
so what is your suggestion?
  #9
Old 10-30-2009, 09:51 PM
E-book Developer
Default
Use P-channel mosfets on top or a high-side driver for N-channel mosfets. Either will work with well documented schematics. At the relatively low power level you are using, I don't really know enough about it to recommend one approach over the other. I have always just used a high-side driver with N-channel mosfets, but my power needs were up to 2 KW.
John
Tags
Related Site Pages
Section Title
Worksheet Basic logic gate troubleshooting
Worksheet CMOS logic gates
Worksheet TTL logic gates
Worksheet Basic logic gates
Worksheet Insulated gate field-effect transistors
Video Lecture MOSFET Amplifiers - Transistors and Transistor Circuits
Textbook Basic gate function : Digital Integrated Circuits
Textbook Insulated-gate field-effect transistors (MOSFET) : Solid-state Device Theory
Textbook Special-output gates : Logic Gates
Textbook CMOS gate circuitry : Logic Gates
Similar Threads
Thread Thread Starter Forum Replies Last Post
MOSFET High Voltage driver (High Side) problem technogamma The Projects Forum 9 10-25-2009 02:29 AM
basic high side mosfet driver help! shortbus General Electronics Chat 9 10-24-2009 01:59 PM
high side mosfet switching sharmilla General Electronics Chat 12 11-03-2008 09:19 PM
Unable to turn off High side mosfet in Full bridge configuration ken_tcs General Electronics Chat 3 08-17-2008 12:58 AM
H Bridge High Side Mosfet Driver bigbigblue General Electronics Chat 31 09-07-2007 10:28 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
