All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-26-2009, 06:14 PM
shafam shafam is offline
Default dumbwaiter control system
I am trying to build a control system for a 3 stop dumbwaiter. I would like to use latching relays and magnetic contacts for simplicity. The lift motor is a 120V reversible hoist that draws 7A. The wall switches I have are Leviton LVS-003. I need help with the circuitry design and sourcing of materials. The open door safety and the slack cable safety are in place, as is a 24V DC power supply for the relays. There are basically three circuits 1 to 2 / 2 to 1, 1 to 3 / 3 to 1, and 2 to 3 / 3 to 2 . If it were only two floors it would be quite simple. My difficulty is how to bypass the middle floor when needed. I want to stay away from electronics that because of my remote location would be unserviceable. Just simple relays and contacts. Can anyone help with a schematic and parts list. Thanks . BOB S.
  #2
Old 10-26-2009, 08:54 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Bob,
Are you talking about this switch:
http://www.leviton.com/OA_HTML/ibeCC...US&item=409013
The LVS-3W was the only reference I found to that on Leviton's site.
Are you in the USA, or elsewhere? It helps a great deal to know your approximate location when attempting to find suitable parts.
A motor that draws 7A @ 120V will probably draw several times that current when it's starting up. Is it a DC or AC motor?
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 10-27-2009, 07:57 PM
Yes that is the switch that i have. The motor is 120V AC. It is a geared reduction motor and an ammeter showed no extra startup amps. I'm in WV in the mountains 2 hours from anywhere, but I do get UPS and Fedex deliveries. In fact I order 80% of everything and have it deleivered. Its cheaper than a 3 or 4 hour round trip to town, and I probably won't find what I need anyway. I can put together relays, limit swithces, etc. from a schemetic, but designing the circuit is something else altogether. Thanks in advance. Bob S.
  #4
Old 10-27-2009, 08:16 PM
SgtWookie's Avatar
Expert Member
Default
OK, you're going to have to tell us more about the motor wiring.
Do you have the instructions on how to make the motor reversible?
Providing a wiring diagram would be very helpful. If you don't have that, the manufacturer's name and the model number of the motor could be used to find a datasheet for it.
__________________
General info:
  #5
Old 10-28-2009, 04:48 PM
williamj's Avatar
williamj williamj is offline
Default
Bob S.,
Not knowing your experience with electrical circuits I feel that I must state the obvious. Not only can 120VAC kill (and has killed) it can also burn down you house. The job you want to do is not an easy one, be careful and thorough.
An instructor I had once said, “Always assume that the person who drew this diagram up was drunk, hung over or just plain having a bad hair day and made some serious life threatening mistakes. Your life is in “YOUR” hands. Act accordingly.”
I have attached a ladder diagram, which I believe will accomplish the task at hand. I also believe that it is error free but you never know. If anyone else reading this thread sees any errors by all means... please speak out!
Do not take this ladder diagram and start wiring up your project. Take the time and make the effort to do a test mockup on a sheet of plywood using a light bulb in place of the motor. Once it is wired correctly and fully tested, then and only then begin work on the dumb waiter itself.
Not only will the mockup test the validity of the circuit but it will also give added and valuable experience.
Good Luck,
williamj
  #6
Old 10-29-2009, 05:18 PM
williamj's Avatar
Default
Bad hair day ALERT!! Bad hair day ALERT!!
The 24V portion of diagram will not work. Apparently a relay for each floor is required. Don't know why I missed that. (bummers) Will revise...
See what I mean about mistakes on drawings and schematics?
Apologies and Mia Copas,
williamj
  #7
Old 10-30-2009, 02:20 PM
williamj's Avatar
Default revised ladder diagrams
Attached are the revised diagrams. Please check thoroughly.
williamj
File Type: jpg Dumb Waiter Control 3 Floor 120V rev.jpg (11.4 KB, 69 views)
File Type: jpg Dumb Waiter Control 3 Floor 24V rev.jpg (41.0 KB, 85 views)
  #8
Old 10-30-2009, 10:17 PM
Default motor info
thanks sgt...the motor is already reversible...it is a hoist motor...the type you might see lifting an engine from a car...880# capacity...16 ft +/- per min cable speed...it has a hand control that i will remove and splice my control circuit to...120v ac comes into the control and goes to two momentary contact push buttons...if you push up power goes back to the motor through one wire...if you push down power goes back to the motor through a different wire...the neutral does not come to the hand control but there is a ground wire for safety...very basic...I am very familiar with AC voltage...I wired the whole house myself...bob s.
williamj...I will print the wiring diagrams and see if I understand them...as I mentioned above, I wired the whole house myself so I understand AC and the risks...whenever possible I kill the power to a circuit before working on any wires in it...thank you very much for your time...bob s.
  #9
Old 10-30-2009, 10:47 PM
Default 3 buttons per floor
won't it will take at least 6 ( maybe 9 ) relays???...from any floor you have two send options to the other floors, and 1 call option if the car is not on your floor...????just thinking out loud...bob s.
  #10
Old 10-30-2009, 11:01 PM
Default still thinking out loud!
and won't 2 limit swithches be required at each floor (possibly 3 on the second floor)?..one limit switch to stop travel, and one as a proximity sensor...for example...if you are on the first floor, to call the car down from upstairs you would press 1, which would activate the motor down...but if the car were already on the first floor and you pressed 1, there has to be something to prevent the motor from going down further...the same for the other floors????headache!!!thanks...bob s.
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Electromechanical relay logic
Worksheet AC motor control circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
LED office-desk lighting system kdaffolder The Projects Forum 1 08-04-2009 07:43 AM
Need help for a dawn/dusk LED circuit malaybiswas The Projects Forum 24 03-04-2009 04:19 PM
Lighting system IR remote control simoncwk The Projects Forum 7 05-23-2008 02:52 AM
Control System nikon Homework Help 4 09-29-2007 02:18 AM
Automotive Control & System Diagnostics Hurdy General Electronics Chat 4 11-01-2006 06:43 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
