Simple transistor circuit help
ScorpFire
Joined Jun 4, 2009
13
Hi im building a simple circuit that uses a Digital Output pin from a modem to turn on an LED.
The modem output pin when high is 2 - 2.8v, when low 0.1 - 0.9v.
The problem is even a LOW Signal turns on the Transistor. Is there any way i could make it such that only a high signal can turn on the transistor? Thanks in advance
SgtWookie
Joined Jul 17, 2007
22,230
Try it more like this:
I changed the configuration around so that the transistor would be saturated instead of an emitter follower.
The addition of the 1N4004 diode keeps the transistor from turning on until the input voltage exceeds about 1.3v.
R1 limits the current through the LED (Vf=2v) to 20mA.
R2 limits the base current.
R3 keeps some current flowing through D1 so that it's Vf stays in the desired range.
ScorpFire
Joined Jun 4, 2009
13
Both high and low outputs from the modem didnt turn on the LED...im guessing theres too much current going into the ground??
CDRIVE
Joined Jul 1, 2008
2,219
If this Modem interfaces to RS232 then there is no need for a transistor Driver. RS232 is more than capable of driving a Led with a 470R to 1K limiting resistor. When RS232 was first introduced it had a typical voltage swing of -30V to +30V. Over the years this standard was lowered to -15V to +15V but RS232 will recognize much lower swings like -5V to +5V.
ScorpFire
Joined Jun 4, 2009
13
Nope its not RS232. Its a standard General Purpose Input Output 2v8 voltage level.
Thanks for your suggestions will try ASAP.
SgtWookie
Joined Jul 17, 2007
22,230
Looking again at the simulation of the circuit I posted, the transistor should be off if the input from the modem is less than 1.5v. Once the modem input reaches 1.95v, the LED should be near it's maximum brightness.
Changing D2 to a 1N4148/1N914 diode and R3 to 2k will reduce the thresholds; below 1.36v the transistor will be off (D1 off) and above 1.7v the transistor will be on (D1 on).
