I search after electronics project that explain exactly how to build an alarm
J Thread Starter joni Joined Oct 4, 2009 39 Oct 17, 2009 #1 I search after electronics project that explain exactly how to build an alarm
Audioguru Joined Dec 20, 2007 11,248 Oct 17, 2009 #2 You forgot to explain what kind of alarm (burglar, water leaking, fire, carbon monoxide, etc).
bluebrakes Joined Oct 17, 2009 253 Oct 17, 2009 #4 what specification are you after? does it need to have door sensors? PIR? more info.
J Thread Starter joni Joined Oct 4, 2009 39 Oct 17, 2009 #5 The component (or the way) in this project is less importantThe important is that I search after book project that explain how to build an alarm for burglarAnd have a drew of the electronic circuit and the code
bertus Joined Apr 5, 2008 22,939 Oct 18, 2009 #6 Hello, There is no need to kick the topic. Here is a page with several circuits: http://uk.geocities.com/ronj_1217/circ.html Again found in the EDUCYPEDIA: http://www.educypedia.be/electronics/circuitssensors.htm Greetings, Bertus
alitex Joined Mar 5, 2007 139 Oct 18, 2009 #7 joni said: thanks burglar Click to expand... the main device is motion detector (sensor)
