I am having a lot of issues with EMI and my sound card (and onboard sound). I know this is the community discussion forum but I like this forum and there is likely to be someone that can help here.
I have an Intel Core 2 Duo E6600 overclocked to 3.15GHz (I don't think I over-volted it, and I think I was having these problems before I did that) an asus p5b deluxe wi-fi AP edition, a geforce 8800gt 512MB and a soundblaster audigy 4 (not pro). When I have my 5.1 speakers plugged into the sound card I get an EMI sound through the speakers and subwoofer if I turn the woofer up more than halfway. The emi is more noticeable in the subwoofer. If I plug a microphone into the pink mic slot it makes a terrible, almost deafening sound (if the microphone itself is turned on). If the microphone is plugged in but turned off it does not. However, if I plug a microphone or another device into line in there is no such issue. To complicate things more I was trying to use gnuitar for effects for my bass and when I turn that program on it amplifies it terribly and I have to close the program.
I tried using the onboard audio for the speakers and I don't get much EMI that way (I can turn the woofer and speakers all the way up and there is no noticeable sound for the most part) but there is still some. There is a very slight, almost imperceptible hum when running gnuitar and every now and then I hear a little bit of something if I am writing something using my wacom tablet. I can plug a normal microphone into the onboard along with the speakers and I do not get the terrible interference; however, if I use the stereo array mic that came with the motherboard it produces that sound. Also, for some reason when I tried playing one of my games (Batman: Arkham Asylum) the sound was really off. I could barely hear the voices in the game (and sometimes not at all) but all the other effects were as loud as they normally would be.
I tried using the audigy 4 as the recording device and the onboard for audio playback but even with nothing else plugged into the audigy the mic port gave off an awful EMI hum or buzz (I don't exactly know the difference).
So:
audigy 4 has noticeable EMI for speakers and unbearable with microphone in mic port. line in does not do this. Cannot use gnuitar or rakarrack without terrible EMI.
onboard audio has very little EMI with speakers (although I would like not to notice it at all) and none that I can tell with a normal mic but the array mic is unbearable. The sound is also messed up somehow in games (perhaps I had it set to 2 speakers instead of 5.1, but that wouldn't be the case unless the auto device recognition did that itself upon reboot). Can use GNUitar with onboard (haven't tried rakarrack as I have mainly been testing in Windows XP).
So basically I want to know how to get rid of this terrible EMI. I want to be able to use my audigy card as the recording device and the sound device without EMI on the speakers (normally or using a guitar effects program). It would also be nice to be able to use the microphones I own. If the onboard audio worked well in games and in Ubuntu, as well as working with the array mic, then I wouldn't worry much about it. However, I did pay about $70 for the sound card a few years ago, and assuming it has its own special devices on it to control audio, I would prefer to use that. Another reason I want the sound card to work is that I have heard that having a dedicated sound card can take some stress off of the CPU in gaming.
Note: my PC tower is an apevia aspire xpleasure and is partly aluminum and partly plastic (the front bay is plastic). It is sitting on carpet but stands a bit off the ground due to its legs.
Thank you.
So:
Thank you.
