| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
Hey, i'm in need of a rule of thumb when choosing the width for 1oz copper during PCB layout. I'm routing a pcb which is used in a 12W linear regulator.
I used to know about a rule which stated that for every amper going trough the trace you needed aprox x many mil of copper width. atm i can't remember what it was. So i was hoping some of you knew it or had suggestions. The trace needs to carry a maximum of 1A. The copper i have is 1 oz. Any help appreciated. |
#2
I've found this to be a useful site.
http://circuitcalculator.com/wordpre...th-calculator/ It is a trace width calculator that goes by the current IPC-2221 (formerly IPC-D-275). I have used the IPC specifications for boards for many PCBs. |
#3
thanks, very helpfull tool.
| Tags |
| advice, copper, routing, trace, width |
Related Site Pages
| Section | Title | |||
| Worksheet | Printed circuit board layout and manufacture | |||
| Worksheet | Electrical connections | |||
| Video Lecture | System Connectivity - Electronic Systems | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| DIY PCBs with 10mil/0.25mm trace width and hole clearance? | DaveH | General Electronics Chat | 18 | 08-05-2009 04:10 PM |
| Thread Tools | |
| Display Modes | |
