| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
Hello all.
Very easy question... Is there a component that would convert vac to vdc that is small enough to mount on a PCB board? Thanks, Alex |
#2
A diode or bridge rectifier will do what you want.
If you gave us more information we can reccomend a part number for you. Wwhat is the voltage What is the current Do you need half wave or full wave rectification Do you need filtering Do you need regulating
__________________
gerty |
#3
Voltage in would be mains voltage at 240VAC, not sure what the current is rated at. I would like to step it down to 24VDC. Filtering and regulation are definite pluses, but not necessary.
#4
Then you need an intermediate device - a step down transformer. It will reduce the voltage and isolate you from the mains. The load current is quite significant for the proper selection of the transformer, though.
__________________
First comes the hardware, then the software. |
#5
I'm a little hesitant on doing this, but should I just plug my probes in there and try to measure current?
Actually now that I think about it, current must be measured in series. So, how do I go about measuring the current that my house receives? A clamp on meter? Is there any other to do this without a clamp on meter? I don't have access to one right now. Last edited by thakid87; 10-02-2009 at 08:04 PM. |
#6
Why don't you tell us exactly what it is you want to do?
In the first post you did not mention dropping the voltage down. Always give all the details you can in the first post and it'll make giving you an answer so much easier.
__________________
gerty |
#7
Sorry, I'll try and be more specific in the future.
#8
When beenthere is asking for the load current he is not asking for the current coming into your house but for the current required at the 24VDC end. What are you going to run on the 24VDC side and how much current does it require? The transformer can only be selected after these details are known.
#9
6-8A max current. I appreciate the help guys.
#10
Then you need a transformer rated for ~250W.
At 8 amps/24 V you are drawing aprox 200W. So you need a transformer at least capable of that. A diode bridge to rectify the AC signal and a capacitor for minimal regulation is probably also needed. |
| Tags |
| converting, vac, vdc |
Related Site Pages
| Section | Title | |||
| Textbook | Voltage multipliers : Diodes And Rectifiers | |||
| Textbook | Clamper circuits : Diodes And Rectifiers | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 120 VAC to 5 VDC Bridge | zpriddy1 | The Projects Forum | 8 | 08-21-2009 07:13 AM |
| Rectifiying of 125 VAC | Landon | General Electronics Chat | 9 | 08-05-2009 06:44 AM |
| Building a 12 VAC to 5 VDC bridge... | sd_sparky | The Projects Forum | 9 | 04-30-2009 02:54 AM |
| 12 VDC to 220 VAC inverter | m javed | The Projects Forum | 2 | 05-11-2008 01:01 AM |
| Thread Tools | |
| Display Modes | |
