All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
View Poll Results: why the efficiency of FWR is double that of HWR.
the ques is not correct 0 0%
no specific answers 0 0%
Voters: 0. You may not vote on this poll
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-27-2009, 12:23 PM
ashuprasad1990 ashuprasad1990 is offline
Post efficiency of half wave and full wave rectifiers
as we know that the efficiency of a half wave rectifier ~=40.6% and that of a full wave rectifier is 81.2%,nearly double that of the HWR...so why this is so...the reason i know is that in HWR only one diode is used and due to rev.biasing it does not conduct so it looses the negative part and in FWR there are 2 diodes(center tapped and also bridge 2 diodes conduct at a time) so its efficiency also doubles....but my professor isn't satisfied with this he wants to know something else.........help needed
  #2
Old 09-27-2009, 01:37 PM
t_n_k t_n_k is offline
Default
Quote:
Where did you get these values and for what circuit conditions do they apply? Are you considering the rectifier in isolation from all other circuit components such as isolation transformers?
  #3
Old 09-27-2009, 03:58 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Just as a thought problem - imagine a capacitor with a constant load drawing current. What difference might be between full wave and half wave charging off a transformer?
__________________
First comes the hardware, then the software.
  #4
Old 09-29-2009, 01:39 AM
Default
yes sir,in this case we are only concerned with their efficiency's in case of transformers
  #5
Old 09-29-2009, 01:42 AM
Exclamation eficiency in case of isolation transformers.
yes sir u r right,i want to know teh reasons for the case of transformers
  #6
Old 09-29-2009, 02:28 AM
Skeebopstop Skeebopstop is offline
Send a message via Skype™ to Skeebopstop
Default
The transformer efficiency depends on the output power and should be read from the transformer spec.
The rectifier efficiency can be easily calculated from the datasheet and input voltage.
For example, lets say Vf (forward voltage) of the diodes is 1V @ 4A RMS. If we consider an RMS in voltage of 100V, the efficiency becomes.
((100V*4A - 1V*4A) / 100V*4A)*100 => 99%.
Now consider a similar scenario, 4A RMS @ 10V RMS in.
((10V*4A - 1V*4A) / 10V*4A)*100 => 90%.
As you can see, the efficiency of a rectifier varies with loading. The same principle applies to Transformers but frequency must also be considered (easier to find a curve in the spec sheet).
  #7
Old 09-29-2009, 02:32 AM
Default
With relevance to my previous post, you must define what you mean by efficiency. Efficiency is typically a term applied to power and not to 'rectification purity'.
The power efficiency between full wave/half wave won't be inherently obvious, however the 'ripple voltage' on the output side will be drastically different.
This question can become quite tricky unless you very accurately define it.
Tags
Related Site Pages
Section Title
Worksheet Basic AC-DC power supplies
Worksheet Rectifier circuits
Video Lecture Power Supplies - Applications - Diodes and Diode Circuits
Textbook Full-wave bridge rectifier : Discrete Semiconductor Circuits
Textbook Full-wave center-tap rectifier : Discrete Semiconductor Circuits
Textbook Voltage multipliers : Diodes And Rectifiers
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Full Wave Vs. Half Wave Rectifier at Small Voltages rperea General Electronics Chat 5 07-26-2009 09:07 PM
A Full wave precision rectifier query trytolearn General Electronics Chat 14 02-12-2009 04:51 PM
Complex Fourier series of full wave rectifier guitarguy12387 Homework Help 6 10-06-2008 09:29 PM
Centre tapped full wave rectification C13Sauber General Electronics Chat 5 08-18-2008 10:05 PM
Half wave rectifier strathy General Electronics Chat 19 03-27-2008 10:06 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
