Voltage Divider Verification
ELECTRONERD
Joined May 26, 2009
1,147
Hey Everyone,
Just want to make sure I'm doing this right.
Suppose I have a voltage divider like in the first attachement. You'll see that R1 = 680Ω and R2 = 20k giving me an output voltage of 8.7V [Vout = R2/(R1+R2)]. Now, to calculate the output current of the voltage divider, you do the following: Iout = Vin/(R1+R2). So my current output is approximately 435μA. Let's say I want to have 2.5μA for my output, I simply add a resistor like in the second attachment. What would the output current be now? Also, wouldn't there be a voltage drop across R3 so I would have to make the voltage a bit larger to compensate for that drop? Ignoring the voltage drop, this is what I did: 435μA - 2.5μA = 437.5μA. So, 8.7V / 437.5μA = 19885.71429Ω ≈ 20k.
Please let me know if I'm doing this right! This is to get the correct base current and voltage to an NPN transistor.
hobbyist
Joined Aug 10, 2008
892
I'm working on it,
but first if you put a resistor in parrallel with your 20K that will lower the total resistance, which then would be a lower voltage out across there.
I'll see if I can come up with an equation to solve for this, then you can caompare notes and see if I got what you came up with.
I'm assuming the R3 is going to ground to allow current to flow?
ELECTRONERD
Joined May 26, 2009
1,147
I'm working on it,
Sounds good! No, R3 goes to the base of the 2N3904 transistor.
ELECTRONERD
Joined May 26, 2009
1,147
Ok that would be a 0.7v. drop to ground.
Assuming no emitter resistor?
This should be able to solve using thevinen equivalency.
I'll work this out and get back to you.
Right, since I want 8V at the emitter, I want 8.7V at the base. Assuming there is no emitter resistor.
According to the 2N3904 specs, on the second page entitled "On Characteristics" you can see that with a hFE of 40 the collector current should be 0.1mA. According to the equation, β=Ic/Ib I can transform that making it to be: Ib=Ic/β. So To make it in its linear region according to the specs, I need Ib=0.1mA/40 = 2.5μA. One thing I'm not sure about is what the emitter resistor should be if I did have one?
hobbyist
Joined Aug 10, 2008
892
the emitter resistance will change the entire input resistance so you would choose a value then rework the base resistors.
But now you have to take into consideration B x RE
hobbyist
Joined Aug 10, 2008
892
I think one way to do it would be to choose your RE value then take the Beta times it for a approx. resistance value then rework the base resistors.
If you could drop the series resistor, then you could do it entirely with a voltage divider itself, reworking the base voltage.
ELECTRONERD
Joined May 26, 2009
1,147
One thing after another, eh? Well, I suppose I would like Re. It affects the gain, right? You're saying that if I do take β x Re into consideration I should probably figure out the emitter resistor before the base resistors? Could you show me what to do?
I know what my collector current should be, according to the 2N3904 specs. So, Rc=9V/0.1mA = 90k.
I also know the base current according to the specs. Since they say in the "On Characteristics" that Ic=0.1mA and Vce=1V that will give you an hFE of 40. So Ib=Ic/β and so my base current should be 2.5μA. Also, since Vce=1V I need the base voltage to be 8.7V so that the emitter voltage will be 8V. Then (I think this is the right equation), Vce=Vc-Ve so that would give me 1V for Vce. I'll need that voltage divider to give me the voltage and that extra R3 to give me the necessary current at the base. Then I would think that I could calculate Re. What should the current be for Re? How do I calculate it?
hobbyist
Joined Aug 10, 2008
892
Let me do a quick calculation using RC as 91K ohms as you stated above and use a volt gain of 10 just to get in the ballpark with this.
90K for Rc won't work with 9V source. thats the the whole supply fropped across that resistor.
let me look at your post and get myself straightened out here.
To be linear the voltage across RC needs to be around 1/2VCC.
I'm still working on this.
hobbyist
Joined Aug 10, 2008
892
Let me back up take it one step at a time.
You waqnt IC=0.1mA.
VCC=9v.
So RC= 4.5V / 0.1mA
(VC= 1/2VCC) to be linear.
RC = 45K make iot 47K ohms
VCE = 1v.
since VCE is chosen then VE is fixed
since Ve is fixed then volt. gain can't be chosen.
VE =3.5v.
RE= VE / IC (ruff estimate)
RE= 36K
not much gain
VB= 4.2v.
RB1=20K to ground
RB2=22K to positive
That's about what I can come up with. for now..
If you change the VCE you can rework the base values to get closer to what you want.
see if this makes any sense and let me know what you think or any questions on how I came up with anything that don't look right.
hobbyist
Joined Aug 10, 2008
892
{{I know what my collector current should be, according to the 2N3904 specs. So, Rc=9V/0.1mA = 90k.}}unquote
Do you see where this is incorrect? The entire voltage is dropped across RC and not the transistor.
{{Right, since I want 8V at the emitter, I want 8.7V at the base. Assuming there is no emitter resistor.}}unquote
Do you see where this leaves no collector resistor ? all the supply voltage is across the emitter resistor RE (8v.) and the transistor (1v.).
I just seen this also
if there is no emitter resistor than you have 0V. at the emitter and base voltage would be 0.7v.
ELECTRONERD
Joined May 26, 2009
1,147
What should I do then? I need those currents, what am I to do?
Now I know what I did wrong, Vc=Vcc/2 so Voltage at collector is 4.5V. Therefore, Rc=45k, correct?
hobbyist
Joined Aug 10, 2008
892
I never really designed a transistor circuit using the spec. data sheets like your doing, so I'll have to go at this one step at a time.
Yes. 45K is the correct answer. standard (47K or 43K)
So lets use 45K for the calculations only.
So far
VCC=9v.
IC=0.1mA
IB=2.5uA
RC=45K
VCE=1v.
Now
VC=4.5v.
and
VCE=1v.
so then VE=3.5v.
Therefor VB will calculate to be 4.2v.
IB=2.5uA
IE=(IC + IB) = 102.5uA
so RE calculates out to (VE / IE) = 34,146 ohms.
Now this is a total guess at the next part I'm doing.
So with 2.5uA branching to the base the divider current should be at least 10 times greater, so lets make ID (divider current) 20.5uA, that would make the grounded resistor in the divider = to { 4.2v. / (20.5uA - 2.5uA) } = 233.333K ohms.
And the top supply resistor = ( (9v - 4.2v) / 20.5uA)= 234.146K ohms
I think...
ELECTRONERD
Joined May 26, 2009
1,147
So far
VCC=9v.
IC=0.1mA
IB=2.5uA
RC=45K
VCE=1v.
Now
VC=4.5v.
and
VCE=1v.
so then VE=3.5v.
IB=2.5uA
I think...
That’s a good conjecture, for sure. That was my entire goal, to be able to look at any transistors specs and design a circuit to saturate it and also design a circuit so it’s a Class-A amplifier. That way, I can take any transistor and design it as efficient as possible for my particular application. I’m sure we’ll both be able to do this soon!
I forgot about how Vc=Vcc/2 so that definitely changed the base voltage. If someone could verify that your conjecture is correct, then all we would have to do is work out the voltage divider problem. One thing I just thought of, if we include R3, should we have the input signal at point A or point B? If we had it at point B it would definitely be more sensitive. You’ll find an attachment showing our complete circuit now. I have most of the values in there. I added C1 which we can calculate depending on our voice frequency.
ELECTRONERD
Joined May 26, 2009
1,147
If anyone else would like to join in please do! I'm sure both hobbyist and I would love to read your comments and suggestions!
hobbyist
Joined Aug 10, 2008
892
Here is a simulation of the bias (static) voltages using the exact calculated values.
These are not too far off from the calculations.
I'll run a dynamic test on the simulator and see what it does.
hobbyist
Joined Aug 10, 2008
892
Here it is with a 10mV. (red) signal in 1khz.
and the output (blue) amd the symetry of the output wave.
Notice hardly no amplifiocation, due to the ratio of RC / RE.
See linearity has to do with the input signal and the available collector current, and the voltage at which the collector is set at, on the load line.
ELECTRONERD
Joined May 26, 2009
1,147
It should be more than that shouldn't it? We should have a gain of 40. Red doesn't appear to be 10mV, your scope says 10mV per division so it is reading 20mV.
