All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-13-2009, 05:41 AM
jesse b jesse b is offline
Default Need help with a Simple 2-LED Driver
I am a novice in the world of circuit design. I have spent several hours googling a solution, without success. I suspect that this is an easy project for some of the participants of this forum.
I need a circuit that lights one of two LEDs depending on the value of an input voltage. A blue (or green) LED lights as the voltage increases from zero to a given threshold. (It doesn’t need to light at very low input voltages.) As the voltage approaches the threshold, the blue LED begins to fade and a red LED begins to light or slowly flash (perhaps the frequency increases as the voltage increases). At the threshold, the blue LED is off and the red light is fully on. The threshold value should be adjustable, perhaps by a small pot.
If the input is insufficient to light the LEDs, I will need a circuit to amplify that input and power the LEDs via a small battery.
Precision is not critical. Compactness and low-cost are important.
I will appreciate any assistance on this project and will be able to build it from a schematic.
  #2
Old 09-14-2009, 02:35 AM
Bernard's Avatar
Bernard Bernard is offline
Default
At threashold , red is fully on, what does red do above threshold?
  #3
Old 09-14-2009, 05:06 AM
Default
The red LED stays on above the threshold.
  #4
Old 09-18-2009, 04:17 AM
Bernard's Avatar
Default
There's hope yet. The blue LED[ really a white] dim at 2V, bright at 3V, dim again at 4.6V. Next the red , will start at 3V, bright at 5V. Used 2 OP Amps so far, next, one for red,& one as comparator from a TL084, quad bifet op amp. Using 12V for now.In put based on a 0-5V signal.
  #5
Old 09-18-2009, 05:37 PM
Bernard's Avatar
Default
Operating on 9V battery, ckt draws about 30mA. A 5k pot used to simulate input signal of 0-9V.Need to adjust V divider to suit your own refference points.'dropped 5V comparator which was to completely turn off blue and turn on red at 5V. Diodes on inputs 3,10 to keep outputs from rising on low input V. Have fun.
Tags
Related Site Pages
Section Title
Textbook CMOS 555 LONG DURATION RED LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION BLUE LED FLASHER : 555 Timer Circuits
Textbook 555 Schmitt Trigger : 555 Timer Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pls help me.Need advice ridge84 Embedded Systems and Microcontrollers 4 11-29-2009 09:35 PM
How to wire up an simple LED with ever changing voltage princess blacklung The Projects Forum 29 09-09-2009 01:56 AM
LED driver and switch advice supakpow The Projects Forum 9 05-27-2009 08:47 AM
Math Help with a Simple LED circuit fish4fun The Projects Forum 3 03-03-2009 04:04 AM
Simple HIgh Current Led Driver bobank The Projects Forum 6 08-03-2007 05:19 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
